LISP function with REST POST API, is it doable ?
Antonin_JubaultSRF25
I want to go on a journey with LISP and before doing so, I thought  I would ask you guys if it's doable.
I want to send a request to a server with a parameter and based on the json answer, use this data to insert a specific bloc into my drawing.
Here is an example :
Let's say I have a server with a house made of rooms who host parameters. Everything in a json file like
[{'house': [{'room_name:bedroom':},{'room_name:kitchen':}]}]
From Autocad, I want the user to be able to call a function with a parameters like "Kitchen" (enter with keyboard) and this function will send a REST POST request to my server which will send back a json file answer and on the autocad side I will be able to use the json value to INSERT block who are having those name "kitchen" into my drawing.
Is it possible ?
Don't hesitate to ask me question if I am not clear 🙂
Thank you so much, so far the help I have received from this community has been amazing.
AJ.
Update :
I have seen the amazing work from CodeDing here
Make an API call with AutoLISP / VisualLISP
Can we update it so a POST function is used and pass a parameter ?
Michiel.Valcke
If you can get the Json as a text string or text file you can read the file with lisp and since you know the structure of the json and what to expect you can write a function to query or select the values that are interesting for you.
https://help.autodesk.com/view/OARX/2025/ENU/?guid=GUID-AC74D827-0969-4888-91C0-C3149DEC3659
I have used similar ideas to read .xml or .ini files to get settings for a program or do secondary license checks etc...
You can also write files. I've used this to write .csv reports, temporary .lin or .pat files, etc...
CodeDing
@Antonin_JubaultSRF25 ,
Yes, it is possible. Below is some code that makes a POST request to a real website. And shows you the successful (fake, but still successful) response. I love this free testing site, I use them often to test code.
Here is the example from the website, scroll down to "Creating a resource" :
https://jsonplaceholder.typicode.com/guide/
The code:
(defun c:TEST ( / url data http_object response)
  (setq
    url  "https://jsonplaceholder.typicode.com/posts"
    data
      (strcat
          "\"title\" : \"foo\","
          "\"body\"  : \"bar\","
          "\"userId\"  : 1"
      );strcat
    http_object (vlax-create-object "WinHTTP.WinHTTPRequest.5.1")
  (vlax-invoke-method http_object 'open "POST" url :vlax-false)
  (vlax-invoke-method http_object 'SetRequestHeader "Content-type" "application/json; charset=UTF-8")
  (vlax-invoke-method http_object 'send data)
  (setq response (vlax-get-property http_object "ResponseText"))
  (if http_object (vlax-release-object http_object))
  (alert response)
  (princ)
Best,
~DD
Amazing thank you so much !
