lisp function value return
GeryKnee
GeryKnee
Hello everyone,
Is there a way to get retained values from a function ??
In the folowing i wish to get the canged by fni value of Val1
(defun fNotify (Value)
(princ (strcat "\n" (strcat "------> " (vl-princ-to-string Value))))
(princ "\n" )
(princ)
(defun fn1 (Val1 )
(setq Val1  123)
(fNotify Val1)  ;;;; ------> 123
(defun c:xx(/ Val1 )
(setq Val1  1 )  ------> 1
(fn1 Val1 )
(fNotify Val1 ) ------> 1 (not 123)
Gery
hak_vz
; here Val1 is defined as global variable that can be availabla to any other
;function
(defun fn1 (Val1 )
(setq Val1  123)
(defun c:xx(/ Val1 ) ; Val1 is defined as local variable to function
;anything after / is consider local variable
(setq Val1  1 )  ------> 1 ; you are setting this local value
(fn1 Val1 ) ; running function with local value
(fNotify Val1 ) ------> 1 (not 123) ; it calls local value that is set to 1 ; ;so it returns 1
(setq Val1 123) ;;; this is global variable
(princ "\n" )
(princ)
(defun fn1 ()
(setq Val1  123)
(fNotify Val1)
(defun c:xx()
(fn1 Val1 )
(fNotify Val1)
Miljenko Hatlak
GeryKnee
thank you hak_vz
So I Have to write as following:
(defun c:xx( / Val1)
(defun fn1 ()
(setq Val1 123)
(fn1)
(fNotify Val1) ;;;; the value of Val1  here is 123
thank you very much,
regards,
Gery.
