Hello Miroslav,
you have said:
'I need to create a LISP that will make me the yellow line like on picture bellow and i dont have a clue how to do that.'
Well, you have asked various codes in this last days, here at the forums, and if you're trying to learn how to code, from the previous codes given to you, were used most of the functions you need to write this code.
You'll have to to study each function from the previous codes...
A starting point for this code:
To get the needed data from the user to write the code:
(if (and (setq pt (getpoint "\nPick point on the line: "))
(setq sel (entsel "\nPick line on which is point, and in the side where you want the new yelow line: "))
(progn (initget 5) (setq len (getdist "\Enter distance of new line: ")))
(setq line1 (car (entsel "\nSelect first reference line: ")))
(setq line2 (car (entsel "\nSelect second reference line: ")))
In the variable 'pt' you'll have the point, in 'sel' a list, first element the line ename and the second a point, from the 'progn' we use initget 5 to force the user to enter a positive value and not just pressing enter to exit, will return from 'getdist' in the variable len a distance, in 'line1' the reference line ename, and in 'line2' the second reference line ename....
To ensure a point on the blue line, try to use the 'vlax-curve-getClosestPointTo' function in 'pt' and in the second element from 'sel'
Use the 'polar' function to get the point in the blue line with the distance from 'len' and the angle from the points returned from 'vlax-curve-getClosestPointTo' function.
To get a new point withe the correct angle from the new line, use the polar function and the angle from the previous one + (/ pi 2.) and a distance 1.0(just to define a vector)
To get the intersection point from the previous vector with the reference lines in 'line1' and 'line2', use the previous two points and the 'inters' function with the start and end points from 'line1' and again with start and end points from line2 ( cdr assoc 10 and 11 from the returned from 'entget' function from 'line1' and 'line2' enames....
To make the new line, use the 'entmake' function with the previous two points returned from 'inters' functions...
Try to write the code, and if you have some difficulties, post back the code you have already written and we'll try to help you...
Hope this helps,
Henrique
