LISP for Xref Draw order
nichkherbsman
nichkherbsman
I need help, I need lisp that arrange the draw order of xref in a dwg file. File that has multiple xref.
What I need is :
Xref 1 will be at the back of Xref 2
Xref 2 will be at the back of Xref 3
Xref 3 will be at the back of Xref 4
that,
Xref 4 will be in front of  Xref 3, 2 & 1
Xref 3 will be in front of Xref 2 & 1
Xref 2 will be in front of Xref 1
And I will just re-arrange the Xref file name in code if I want to change the draw order of Xref or if I attach new xref.
Thank you.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
ВeekeeCZ
Perhaps like this.
(defun c:XrefDraworder ( / :Move1stXrefUnder2nd :SSXref)
  (defun :SSXref (name / ) (ssget "_A" (list '(0 . "INSERT") (cons 2 name))))
  (defun :Move1stXrefUnder2nd (mov ref / ss-ref ss-mov eco)
    (setq eco (getvar 'cmdecho)) (setvar 'cmdecho 0)
    (or (and (setq ss-ref (:SSXref ref))
	     (setq ss-mov (:SSXref mov))
	     (initcommandversion)
	     (vl-cmdf "_.DRAWORDER" ss-mov "" "_U" ss-ref "")
	     (princ (strcat "\nMoving '" mov "' under '" ref "' done."))
	(prompt (strcat "\nMoving '" mov "' under '" ref "' failed.")))
    (setvar 'cmdecho eco))
  (:Move1stXrefUnder2nd "Xref3" "Xref4")
  (:Move1stXrefUnder2nd "Xref2" "Xref3")
  (:Move1stXrefUnder2nd "Xref1" "Xref2")
  (princ)
nichkherbsman
Thank you. I will try this lisp.
NiCHKCiD
BIM Modeler
Technical Officer
Technical Designer
Sr. Draftsman
