Lisp for transforming several texts into the same several different mtext
virgilius99
Message 1 of 12
virgilius99
Hi, I need a lisp for transforming several texts into the same several different mtext, thx!
Replies (11)
Message 2 of 12
CodeDing
@virgilius99 ,
Do you have Express Tools loaded? If so, have you tried the TXT2MTXT command?
Best,
~DD
Message 3 of 12
virgilius99
yes, take a look at drawing in att, thx
Message 4 of 12
Kent1Cooper
Try Text1MtextJust.lsp with its T1MJ command, available >here<.  Not only does it convert individual Text objects into individual separate Mtext objects, but it also does it to Attribute definitions, and it preserves all aspects of justification, which TXT2MTXT does not always do.
Kent Cooper, AIA
Message 5 of 12
dlanorh
At its most basic
(defun c:T2MT (/ c_doc sv_lst sv_vals ss cnt)
  (vl-load-com)
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        sv_lst (list 'cmdecho 'osmode)
        sv_vals (mapcar 'getvar sv_lst)
  );_end_setq
  (mapcar 'setvar sv_lst '(0 0))
  (setq ss (ssget '((0 . "TEXT"))))
  (cond (ss
          (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-endundomark c_doc))
          (vla-startundomark c_doc)
          (repeat (setq cnt (sslength ss))
            (vl-cmdf "txt2mtxt" (ssname ss (setq cnt (1- cnt))) "")
          (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
  (mapcar 'setvar sv_lst sv_vals)
  (princ)
I am not one of the robots you're looking for
Message 6 of 12
virgilius99
this is it! thx you!
Message 7 of 12
krazeymike
Is it easy to add a Bottom Centre justification to the created MText?
Message 8 of 12
Kent1Cooper
If the source Text object is justified that way, T1MJ will make the Mtext conversion likewise.  If not, this will give the VLA object version [the obj variable here] of an Mtext object that justification:
(vla-put-AttachmentPoint obj 8)
Kent Cooper, AIA
Message 9 of 12
krazeymike
Thankyou Kent, I'm just not sure how to add (vla-put-AttachmentPoint obj 8) into the M2MT Lisp above
Message 10 of 12
Kent1Cooper
Do you mean T2MT in Message 5?  If so, I hope just adding a line [here, line 3] would do it [untested]:
            (vla-put-AttachmentPoint (vlax-ename->vla-object (entlast)) 8)
[That assumes that the TXT2MTXT conversion inside there results in a new entity name, as it does manually.]
Kent Cooper, AIA
Message 11 of 12
krazeymike
Yes I did mean T2MT on in message 5.
Pasting it into Line 3 wouldn't run but placing it before the (princ) on line 27 worked like a charm.
Thankyou
Message 12 of 12
krazeymike
(Original Edited)
I went a bit off topic here, can't delete so I have edited instead. Thanks for the help Kent
I have a Lisp routine that converts mText or Text to blocks about the insertion point. The only problem is that no matter the justification standard text is always inserted to the left node rather than the centre.
I'm not sure what causes standard text insertion to default to the left node and so am not sure where to look to correct this.
