LISP for text to multileader?
jboyceQPURR
Message 1 of 10
jboyceQPURR
Whenever I export from Revit to CAD, all the annotations get broken up, so it's MTEXT and then the arrow/line are separate. Is there a lisp to convert all that text and make a multileader out of it? I don't wanna copy and paste each one into a multileader.
Thanks!
Replies (9)
Message 2 of 10
devitg
Please upload a sample dwg
Message 3 of 10
sean.keohane
I'm not sure where I got this one but it copies a selected text string to a multileader, might be what you need.
regards
Sean
Message 4 of 10
jboyceQPURR
That was it! thank you very much.
Message 5 of 10
Imanthie_BandaraCPANR
Hello, what's the command I need to use after loading this lisp?
Message 6 of 10
jboyceQPURR
"AM"
Message 7 of 10
Sea-Haven
in most lisps posted here you will see (defun C:..... the C: implies this defun can be invoked by typing its name as a command. A simple method so you dont forgot how to run.
Look at end of code.
  (princ)
change to
(princ "\nTo run command Type AM ")
  (princ)
Message 8 of 10
I loaded the lisp gave the command "AM" gave the leader location. When I enter the leader remained. The text disappears. Can you help ,e to solve this please, Thank you!!
Message 9 of 10
jboyceQPURR
Click on the text first. Then type "am". Hit enter. Then click where you want the leader pointer, then click again to place the text.
Message 10 of 10
jboyceQPURR
Type "am"
Hit enter
Left click where you want the leader arrow
Left click again where you want the text to go
Make sure your multileader is set to a proper text leader.
