LISP for Selection of alternate lines from the selection set of lines like 1st, 3rd, 5th, .....etc lines in autocad.
pankaj
pankaj
Hello guys,
I need LISP for Selection of alternate lines from the selection set of lines(horizontal, vertical & Angular) like 1st, 3rd, 5th, .....etc lines in Autocad.
I am attaching the file with my requirement in the following cases,
Case 1: Angular lines
Case 2: vertical lines(angle 90 or 270 degree angle lines)
Case 3
: Horizontal lines(angle 0 & 180 degree angle lines)
For Case 2 & Case 3 i got the solution of lisp from the following link
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-select-a-set-object-in-alter...
with the following code by komondormrex(Thanks you sir)
(defun c:even_odd_alternate_pattern_sset ( / lines_sset lines_sset_list command_terminated odd_order line_angle testing_coordinate
											 alternate_sset alternate_index ename
	(if (setq lines_sset (cadr (ssgetfirst)))
		(sssetfirst)
		(setq lines_sset (ssget '((0 . "line"))))
 	(setq lines_sset_list (vl-remove-if 'listp (mapcar 'cadr (ssnamex lines_sset))))
	(cond
			(or
				(equal (* 1.5 pi) (setq line_angle (vla-get-angle (vlax-ename->vla-object (car lines_sset_list)))) 1e-2)
				(equal (* 0.5 pi) line_angle 1e-2)
				(setq testing_coordinate 'car)		;	vertical
			(or
				(equal (* 0.0 pi) line_angle 1e-2)
				(equal (* 1.0 pi) line_angle 1e-2)
				(setq testing_coordinate 'cadr) 	;	horizontal
			t
				(setq testing_coordinate 'skip)
	(if (not (= testing_coordinate 'skip))
		(setq lines_sset_list (vl-sort (mapcar '(lambda (line) (cons line (apply testing_coordinate (list (vlax-get (vlax-ename->vla-object line) 'startpoint)))))
												lines_sset_list
									   '(lambda (line_1 line_2) (< (cdr line_1) (cdr line_2)))
	(sssetfirst nil lines_sset)
	(prompt "\rPress <Space> to see alternate pattern, <Esc,Enter> to confirm")
	(while (not command_terminated)
			(setq error_occurred (if (vl-catch-all-error-p (setq grread_data (vl-catch-all-apply 'grread (list t 12 0)))) t nil))
	    	(cond
					error_occurred                                                              ;	Esc
						(setq command_terminated t)
				 	(equal grread_data '(2 32))													;	Space
						(sssetfirst)
						(setq alternate_sset (ssadd)
							  alternate_index 0
						(if odd_order
							(setq alternate_index 1)
							(setq alternate_index 0)
					  	(setq odd_order (not odd_order))
						(while (setq ename (car (nth alternate_index lines_sset_list)))
							(ssadd ename alternate_sset)
							(setq alternate_index (+ 2 alternate_index))
						(sssetfirst nil alternate_sset)
				 	(equal grread_data '(2 13))													;	Enter
	(princ)
Please help me out with an possible lisp solution for case 1.
Also,
Is there a Autocad Plugin to do this?
If so Please share it.
Thanks in advance,
Pankaj
Accepted solutions (3)
Sea-Haven
komondormrex
hey,
check the following. alternating ssets are formed from originally fenced entities.
(defun crd (_list)
	(reverse (cdr (reverse _list)))
(defun draw_pline (point_list pline_exist / pline_coordinates_array pline_coordinates_List)
    (setq pline_coordinates_array (vlax-make-safearray
										vlax-vbdouble
								  	    (cons 1 (length (setq pline_coordinates_list
													   		(apply 'append
																   (mapcar 'crd
																			(mapcar '(lambda (point) (trans point 1 0))
																					 point_list
    (vlax-safearray-fill pline_coordinates_array pline_coordinates_list)
	(if pline_exist
    	(vla-put-coordinates fence_object pline_coordinates_array)
		(progn
			(setq fence_object (vla-addlightweightpolyline (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
			(vla-put-color fence_object 1)
			(vla-put-constantwidth fence_object 30)
(defun c:even_odd_alternate_pattern_sset (/ fence_list fence_object pline_exist next_point lines_sset_list command_terminated
											error_occurred grread_data alternate_sset alternate_index odd_order ename
	(setq fence_list (append fence_list (list (setq next_point (getpoint "\nPick starting point for object selecting with fence: ")))))
	(while (setq next_point (getpoint next_point "\nPick next point for object selecting with fence (RMB to stop fencing): "))
		(setq fence_list (append fence_list (list next_point)))
		(draw_pline fence_list pline_exist)
		(if (not pline_exist) (setq pline_exist t))
		(sssetfirst nil (setq lines_sset (ssget "_f" fence_list)))
	(vla-erase fence_object)
	(prompt "\rPress <Space> to see alternate pattern, <Esc or Enter> to confirm")
	    	(cond
						(sssetfirst)
							  alternate_index 0
						(if odd_order
						(while (setq ename (nth alternate_index lines_sset_list))
	(princ)
Kent1Cooper
Case 3
For Case 2 & Case 3 i got the solution ....
>This< from that other topic works on angular lines.
Kent Cooper, AIA
