lisp for sanitary branch line
LDShaw
LDShaw
I am having trouble with a simple routine that asks for main line, branch line then intersection.
Basically it's going to put an 8' 45° angle between two lines ask for a rotation then trim the branch.
Once that's done it's going to copy said line at the intersection of the next branch  keep the rotation and ask for a trim.
Trouble are in order of importance.
1. I can't get the repeat (I took the repeat out in the example.) of the branch line command  to work right.
2. I can't figure out how to do an apparent intersection that works well. This one is not real important as a tracking to intersection seems to do the trick.
As a side not it would be a nice but not a have to have if this would also to a 45° branch line.
Any help would be appreciated.
Thank you.
(defun c:Sanitary ()
;sets main and branch lines
(setq a (entsel "\nSelect main line")
      b (entsel "\nselect branch line")
	  e (getpoint"\nChoose intersection of branch and main line")
;branch lines will be made same layer as main line.
(command "LAYMCUR" a)
(command "MATCHPROP" a b "")
;draws connection and places it at intersection of branch and main line.
(command "line" "0,0" "@8<45" "")
(setq c (entlast))
(command "copy" c "" "5.65625,0" e)
(setq d (entlast))
(command "erase" c "")
(command "rotate" d "" "@" pause)
;trims  branch line
(command "trim" d "" pause "")
;repeats bracnh line.
(setq  f (getpoint"\nChoose intersection of branch and main line"))
(command "copy" d "" e  f)
(setq d (entlast))
(command "trim" d "" pause)
CodeDing
@LDShaw ,
I actually do not fully understand what your end state is supposed to look like? Can you post a before / after of how your dwg WOULD look?
Here is a fresh take on what I'm interpreting from your code. You can definitely use "COMMAND" references like you do, but I mixed in some more-advanced items to help get new ideas into your mind.
If you have questions, don't hesitate to ask.
(defun c:SANITARY ( / main bran iPt lyr e)
;get selections from user
(if (not (and (setq main (car (entsel "\nSelect Main Line: ")))
	      (setq bran (car (entsel "\nSelect Branch Line: ")))
	      (setq iPt (getpoint "\nSelect Intersection of Main and Branch line: "))))
  (progn (prompt "\n...Cannot skip selections. Try again.") (exit))
);if
;set branch layer to same as main
(setq lyr (cdr (assoc 8 (entget main))))
(setpropertyvalue bran "LayerId" (tblobjname "LAYER" lyr))
(while iPt
  ;create connection line
  ;assumes base direction is EAST & angle direction is COUNTERCLOCKWISE
  (setq e (entmakex (list '(0 . "LINE") (cons 8 lyr) (cons 10 (polar iPt pi 5.65685))
  			(cons 11 (polar iPt (* 0.5 pi) 5.65685)))))
  ;let user rotate & trim
  (command "_.ROTATE" e "" iPt pause)
  (command "_.TRIM" e "" pause "")
  ;repeat branch line
);while
;finish up
(prompt "\nSANITARY Complete...")
(princ)
);defun
Best,
~DD
LDShaw
I was looking for the advanced way to do it and your example shows it to me. Thank you!
Here is what I am trying to accomplish. Your example is more than sufficient for me to figure out where I went wrong. It was a great help.EXAMPLE.PNG
Sea-Haven
An alternative method suggestion
pick main near end this defines direction of 45 line not in a "and"
use "while" then pick verticals
use intersectionwith to work out inters point then adjust back towards start, 8' point on main 8/1.414 etc
draw 45 line
using fillet do just that picked line and new 45 line this avoids working out trims etc fillet obj1 (entlast)
obviously do layer stuff.
ronjonp
Could you not use a dynamic block with an alignment parameter and visibility for the different circles at the ends?
LDShaw
Sometimes a dynamic block would work others times it would not. Saying that I would be open to hearing how others put in their sanitary systems. Lisp and standards are always an interesting talk.
_Tharwat
Here is a very advanced Drainage Program: Drainage Program
