lisp for periodically purging / cleaning drawing
barry2104
barry2104
I found an old lisp on a german CAD forum to purge a drawing without having a dialog box pop up and was wondering if someone can amend it to include the following actions:
1) delete any duplicate objects (to an accuracy of 0.001) --> Command: "overkill"?
2) delete any unused scales (text, annotation, etc)
3) color -->By Layer
4) linetype --> By Layer
5) lineweight --> By Layer
6?) any other recommended purge-type features to build in?
Perhaps there's a fitting lisp out there that already exists and I just can't find it...
PS: if i wanted to create a button for this command, to add to a particular ribbon, how would I go about this? Can I create/choose a jpg (or bmp?) for this button/icon?
;** Datei REINIG
;** Dient zum automatischen bereinigen von Zeichnungen
;** Funktion C:REINIG
;**          Hauptprogramm
;** Autor: NAVRATIL Heinz
;** Stand: 22.11.1998
;** Ver.:  2.0 -- AutoCAD Ver. 14 / 2000
;** C:REINIG
(defun C:REINIG( / ok oldecho)
  (setq oldecho (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (setq ok T)
  ;* Solange OK T ist
  (while ok
    ;* Befehl BEREINIG aufrufen
    (command "._PURGE" "_AL" "*" "_Y")
    ;* Wenn der Befehl nach dem Aufruf noch aktiv ist, bedeudet das,
    ;* daß es noch Elemente zum Bereinigen gibt.
    (if (= (getvar "CMDACTIVE") 1)
      (progn
        ;* Solange der befehl aktiv ist wird mit _Y geantwortet
        (while (= (getvar "cmdactive") 1)
          (command "_Y")
      ;* Wenn nach dem Befehlsaufruf BEREINIG wieder beendet wird,
      ;* gibt es nichts mehr zu bereinigen.
      (setq ok nil)
  (setvar "CMDECHO" oldecho)
  'DANKE
Running AutoCAD Architecture 2020, in German
john.uhden
I didn't read much of your post, but I'm pretty sure you could set up a reactor that calls the -PURGE command (a command line version).  That way you could rid your DWG of those multitudinous regapps as well.
John F. Uhden
pbejse
@barry2104 wrote:
..PS: if i wanted to create a button for this command, to add to a particular ribbon, how would I go about this? Can I create/choose a jpg (or bmp?) for this button/icon?
Another option is to use Tool Palette. Adding Lisp Files to a Tool Palette and yes, the article also shows defining an image to use as a button.
