LISP for Pattern Dimension
Jason.Rugg
Message 1 of 9
Jason.Rugg
I have an old LISP that I need to update it to format my dimension text correctly. I have not used LISP in a long time so I am lost. Using the LISP below, I need to finished dimension value to read in the following format:
12 EQ. SP. @ 1" = <<>>
(defun c:@Dims (/ dist ss n eo)
 (if (and (setq dist (getdist "\nSpecify increment distance: "))
          (setq ss (ssget '((0 . "DIMENSION"))))
   (progn
     (setq n (sslength ss))
     (while (> (setq n (1- n)) -1)
       (setq eo (vlax-ename->vla-object (ssname ss n)))
       (vla-put-AltUnitsScale eo dist)
       (vla-put-LinearScaleFactor eo (/ 1.0 dist))
       (vla-put-TextOverride
         eo
         (strcat "[%<\\AcExpr (1+%<\\AcObjProp Object(%<\\_ObjId "
                 (itoa (vla-get-ObjectID eo))
                 ">%).Measurement \\f \"%lu2%pr0\">%) \\f \"%lu2%pr0\">%]\\X@ %<\\AcObjProp Object(%<\\_ObjId "
                 ">%).AltUnitsScale \\f \"%lu2%pr0\">% C/C"
       (vla-Update eo)
 (command "._UpdateField" ss "")
 (princ)
Replies (8)
Message 2 of 9
devitg
Please upload your sample.dwg
Message 3 of 9
Jason.Rugg
@devitgI don't have a sample drawing, it can be used on any dimensioned drawing. To use it, you just select two points (patterned holes) and then select the overall dimension and it does the math for you.
Message 4 of 9
devitg
How you think I can know ,how?
Please put some effort to show us how you need to be , in a sample.dwg
Message 5 of 9
ronjonp
Maybe this?
(defun c:@dims (/ dist ss n eo)
	   (setq ss (ssget ":L" '((0 . "DIMENSION"))))
    (progn
	(vla-put-altunitsscale eo dist)
	(vla-put-linearscalefactor eo (/ 1.0 dist))
	(vla-put-textoverride
	  eo
	  (strcat
	    "%<\\AcExpr (1+%<\\AcObjProp Object(%<\\_ObjId "
	    (itoa (vla-get-objectid eo))
	    ">%).Measurement \\f \"%lu2%pr0\">%) \\f \"%lu2%pr0\">% EQ. SP.\\X@ %<\\AcObjProp Object(%<\\_ObjId "
	    ">%).AltUnitsScale \\f \"%lu2%pr0\">% = <<>>"
	(vla-update eo)
  (princ)
Message 6 of 9
Jason.Rugg
@ronjonpThis is working pretty good, two more tweaks I need to make though. The field that gets filled in after the @ symbol, can it be formatted to have the inch " mark behind it?
Second, what do I need to change to get it to calculate the number of spaces for the first field? Currently it is calculating the number of objects in the pattern instead of the number of spaces between the objects in the pattern. So if I have a hole pattern with 4 holes I need it to caluculate that there are 3 equal spaces.
Message 7 of 9
ronjonp
Maybe this?
Code tags seem to be busted right now that's why it's attached.
Changes made for reference:
Message 8 of 9
Jason.Rugg
@ronjonpThat worked great. I ran the code on a really big dimension and the field after @ stays in inches. So the 32'-9" increment space that I am using is filled out as 394". What keeps that in inches instead of giving me feet and inches?
Message 9 of 9
ronjonp
The units are hardcoded in the field '%lu3%pr0' <- lunits 2 luprec 0. Try this ( no lisp format ATM )
    (progn
	  eo
	  (strcat
	    "%<\\AcExpr (%<\\AcObjProp Object(%<\\_ObjId "
	    ">%).Measurement \\f \"%lu3%pr0\">%) \\f \"%lu2%pr0\">% EQ. SP.\\X@ %<\\AcObjProp Object(%<\\_ObjId "
	    ">%).AltUnitsScale \\f \"%lu3%pr0\">% = <<>>"
	(vla-update eo)
  (princ)
