Lisp for Layer Name, Description start and end coordinates
nislam04
nislam04
I am badly in need of a Lisp for Layer Name, Description start and end coordinates listed on a txt file.
Like: Name, Description, x1, y1, z1, x2, y2, z2
Any one can help sending me a link for that please?
Thank you
paullimapa
Layers do not have start & end coordinates...please clarify.
Paul Li
IT Specialist
@The Office
Sea-Haven
Do you mean line work ?
nislam04
Thank you for your response.
In fact I want to make a list like this from the lines/polylines of a drawings:
//Time:
//File Location:
//Number of lines on the drawing:
W8X10,      w,BEAM,B,3,       441.87,677.87,0.00,     517.80,677.87,0.00
Thank you very much
Sea-Haven
Ok we now know lines and plines, the latter I take 2 points only.
So next question what do we do with all the answers we get ?
Copy this to command line it will tell you how many objects found.
(sslength (ssget "X" '((0 . "*line"))))
Moshe-A
@nislam04 ,
did you look at DATAEXTRACTION command?
Moshe
calderg1000
Regards @nislam04
Try this code
Export the information of selected lines and polylines to a *txt file.
(defun c:ldat (/ fname fn s i sn la sp ep ln lp lpx)
  (if (setq s (ssget '((0 . "*line"))))
    (progn
      (setq fname (getfiled "Save Text File As:" "" "txt" 1))
      (setq fn (open fname "w"))
      (repeat (setq i (sslength s))
        (setq
          sn  (vlax-ename->vla-object (ssname s (setq i (1- i))))
          la  (vlax-get sn 'layer)
          ln  (vlax-get (vlax-ename->vla-object (tblobjname "LAYER" la))
                        'Description
          sp  (vlax-curve-getstartpoint sn)
          ep  (vlax-curve-getendpoint sn)
          lpx
              (strcat
                la
                ln
                (apply 'strcat (mapcar '(lambda (x) (strcat (rtos x) ",")) sp))
                (apply 'strcat (mapcar '(lambda (x) (strcat (rtos x) ",")) ep))
        (write-line lpx fn)
    (close fn)
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
