LISP FOR HATCH TRANSPARANCY
larsr2866
larsr2866
Good afternoon everyone,
I have a question. I have a lisp code to change all my hatches to a specific color. But is it also possible to give all these hatches a transparancy of 60%?
  (if (setq sst (acet-ss-ssget-filter ss '((0 . "HATCH"))))
    (command "_.CHPROP" sst "" "_Color" "_True" '"300,297,250" ""))
Thanks in advance.
Lars
dbhunia
Try like this.......
(if (setq sst (ssget '((0 . "HATCH"))))
  (progn
    (command "_.CHPROP" sst "" "_Color" "_True" "255,255,255" "");; R,G,B color value should be 0 to 255
    (repeat (setq n (sslength sst))
      (setq itm (ssname sst (setq n (1- n))))
      (setq obj (vlax-ename->vla-object itm))
      (if (vlax-write-enabled-p obj) (vla-put-entitytransparency obj 60));; Here Transparency is 60%
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
larsr2866
Thank you for your answer.
Ik works, but it doesn't change it automatically to all hatches. I have to select the hatches first.
Can i get this working without the user input?
ВeekeeCZ
 Best if you look eg. HERE to learn how to fix it by yourself.
larsr2866
Thanks for the link, BeekeeCZ.
The ssget "_A" ' did the trick 🙂
