LISP for editing XREF layers with specific Description?
Message 1 of 12
When plotting drawing definitions, we often have many unnecessary layers visible that we don't need on the final plot, namely layers that contain the word "Rives" (= demolish) in the description. These take time to edit manually and it would be nice to have a button that turns all of those layers off, as well as making them unplottable and selecting VP Freeze in Layer Properties Manager.
Some help coding this would be greatly appreciated.
Replies (11)
Message 2 of 12
cadffm
Where is your current code? Where do you need help?
Iterate thru all Layers, Layernames with a pipe"|" are XRef-Layers,
check the xdata of AcAecLayerStandard application,
check the name of the description, if match to "*Rivas*", thats your Layer..
For AutoLISP:
iterate with TBLNEXT
Description is the second dxf code 1000 from AcAecLayerStandard application
Set DXF 290 to1 (non-plot)
Use the VPLAYER to VPFREEZE them (or create a list of Layernames, which you apply layer all in one step with VPLAYER command)
(entget(tblobjname "LAYER" "0")'("AcAecLayerStandard")))
(-1 . <Objektname: 7ff6127bc900>)
(0 . "LAYER")
(5 . "10")
(102 . "{ACAD_XDICTIONARY")
(360 . <Objektname: 7ff6127ec240>)
(102 . "}")
(330 . <Objektname: 7ff6127bc820>)
(100 . "AcDbSymbolTableRecord")
(100 . "AcDbLayerTableRecord")
(2 . "0")
(70 . 0)
(62 . 7)
(6 . "Continuous")
(290 . 1)
(370 . -3)
(390 . <Objektname: 7ff6127bc8f0>)
(347 . <Objektname: 7ff6127bcee0>)
(348 . <Objektname: 0>)
(-3 ("AcAecLayerStandard" (1000 . "") (1000 . "hello"))
Where exactly do you need more help?
Sebastian
Message 3 of 12
cadffm
I see (now) you have a code which handle with XREF-Layers, => Re: LSP/SCR button for selecting and lock all XREFs
so you can use this construct as base and add/edit what you want.
Sebastian
Message 4 of 12
This is my current code:
(vl-load-com)
(defun c:lockallxrefs (/ *error* c_doc c_lyrs lyr_name)
	(defun *error* ( msg )
		(if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
		(if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred.")))
		(princ)
	);end_defun_*error*
	(setq c_doc (vla-get-ActiveDocument (vlax-get-acad-object))
        c_lyrs (vla-get-layers c_doc)
	);end_setq
	(vla-startundomark c_doc)
	(vlax-for lyr c_lyrs
    (setq lyr_name (vla-get-name lyr))
    (if (= (vla-get-lock lyr) :vlax-false)
      (if (or (wcmatch lyr_name "XREF" )
              (wcmatch lyr_name "XR-*" )
	(progn
          (vla-put-lock lyr :vlax-true)
          (cond (t (COMMAND "-layer" "_tr" 50 lyr_name ""))
          );end_cond
        );end_progn
      );end_if
    );end_if
  );end_for
	(princ)
);end_defun
Still not that used to coding, so I'm not sure exactly which variable is which.
Message 5 of 12
dlanorh
Sorry I can't help at the moment but this
	(progn
          );end_cond
        );end_progn
      );end_if
    );end_if
  );end_for
Is the main loop through the layers, and you need to
(setq description (vla-get-description lyr))
then wcmatch the description string for what you are looking for using wildcards allowing for it being at the start, at the end or in the middle of the string.
Hope this helps
I am not one of the robots you're looking for
Message 6 of 12
dlanorh
Do you want the VP Freeze to work for a specific layout or all layouts in the drawing?
Message 7 of 12
For all layouts. We only use one layout per dwg, so it doesn't need to be specific. Rather those layers don't risk showing at all when plotting, regardless of settings.
Message 8 of 12
dlanorh
Thanks. two further questions.
Are there multiple viewports per layout or just one?
Do you want this as a separate lisp or integrating into the previous one?
Message 9 of 12
dlanorh
Try this :
(vl-load-com)
(defun c:XRO (/ *error* c_doc c_lyrs lyr_name lyr_desc lyrs_str t_mode)
    (if (and t_mode (/= t_mode (getvar 'tilemode))) (setvar 'tilemode t_mode))
		(princ)
	);end_defun_*error*
	(setq c_doc (vla-get-activedocument (vlax-get-acad-object))
	);end_setq
    (setq lyr_name (vlax-get-property lyr 'name)
          lyr_desc (vlax-get-property lyr 'description)
    );end_setq
    (cond ( (or (wcmatch lyr_desc "Rives*")  ;These wcmatch functions are case sensitive. This line tests if it is the first word in the description
                (wcmatch lyr_desc "*Rives*") ;If this is picking up parts of words try using "* Rives *" in place of "*Rives*". This tests if it is somewhere in the middle
                (wcmatch lyr_desc "*Rives")  ;This tests if it is the last word in the description
            );end_or
            (vlax-put-property lyr 'layeron :vlax-false)
            (vlax-put-property lyr 'plottable :vlax-false)
            (if lyrs_str
              (setq lyrs_str (strcat lyrs_str "," lyr_name)); This builds a string of layer names separated by comma for passing to the vplayer command
              (setq lyrs_str lyr_name)
            );end_if
          );end_layer_description_contains_Rives_sub_cond
    );end_cond
  );end_for
  (setq t_mode (getvar 'tilemode))
  (if (/= t_mode 0) (setvar 'tilemode 0));set paperspace
  (vl-cmdf "_.vplayer" "_F" lyrs_str "_A" "")
  (if (= t_mode 1) (setvar 'tilemode t_mode));reset tilemode
	(princ)
);end_defun
It can be run from modelspace or paperspace. If run from modelspace you will probably notice a flicker as it changes to paperspace and back.
Message 10 of 12
 Works nicely! Thanks!
The only thing missing is also checking the "New VP Freeze" icon for selected layers. I'd add it in myself, but I don't know the code command for it:
(vl-load-com)
		(princ)
	);end_defun_*error*
	);end_setq
    );end_setq
            );end_or
            (vlax-put-property lyr 'newvpfreeze :vlax-true)?
            (if lyrs_str
            );end_if
    );end_cond
  );end_for
	(princ)
);end_defun
Message 11 of 12
dlanorh
Almost, but it's not as logical as that. Robot Happy
It's
(vlax-put-property lyr 'viewportdefault :vlax-true)
Message 12 of 12
Thank you! Perfect! Smiley Happy
