I hope this helps you.
;;=========================== C:tstfunc005 ====================================
;; Jose L. García G. - 18/08/17
(defun C:tstfunc005 ( / oCurve ssPoints
;|functions|; jlgg-SSToList jlgg-MakeRotatedDimension
;;-------------------------- jlgg-SSToList -----------------------
;; Selection set --> list of entities
(defun jlgg-SSToList (ss / ssl n)
(if (and ss (= (type ss) 'PICKSET))
(repeat (setq n (sslength ss))
(setq ssl (cons (ssname ss (setq n (1- n))) ssl))))
);c.defun
;;------------------------ jlgg-MakeRotatedDimension ----------------------------
;;Crea una cota Girada
;;Jose L. García G. - Hispacad.com
(defun jlgg-MakeRotatedDimension (Pt1 Pt2 PtTxT Txt / LstMk EntCota ModEnt)
(cond ((not Txt) (setq Txt ""))
((= (vl-string-trim " " Txt) "") (setq Txt "")))
(setq LstMk
(list
'(0 . "DIMENSION") '(100 . "AcDbEntity")'(100 . "AcDbDimension")
;;(cons 8 *LAY*)
(cons 11 PtTxT)(cons 10 PtTxT)
'(12 0.0 0.0 0.0) '(70 . 32)
(cons 1 Txt)
'(71 . 5) '(72 . 1)
'(41 . 1.0) '(42 . 0.0)'(52 . 0.0) '(53 . 0.0) '(54 . 0.0) '(51 . 0.0)
(cons 3 (getvar "DIMSTYLE"))
'(100 . "AcDbAlignedDimension")
(cons 13 Pt1)
(cons 14 Pt2)
'(15 0.0 0.0 0.0) '(16 0.0 0.0 0.0)
'(40 . 0.0)
(cons 50 (angle pt1 pt2))
'(100 . "AcDbRotatedDimension")
);c.list
);c.setq
(setq EntCota (entmakex LstMk))
);c.defun
;;------------------------ MAIN ----------------------------------------
(cond
((and (not (prompt "\nSelect curve base: "))
(not (setq oCurve (ssget "_:S:E:N" '((0 . "*LINE,ARC,ELLIPSE,CIRCLE"))))))
(prompt "\nNo valid base curve selected: (poliline, line, arc, circle, spline, ellipse,..)")
((and (not (prompt "\nSelect points: "))
(not (setq ssPoints (ssget '((0 . "POINT"))))))
(prompt "\nNo points selected..")
(T
(setq oCurve (ssname oCurve 0)) oCurve ssPoints
(mapcar
(function
(lambda (oPt / Ang pnt p1)
(setq pnt (cdr (assoc 10 (entget oPt))))
(setq p1 (vlax-curve-getClosestPointTo oCurve pnt));point on curve
(setq Ang (angle p1 pnt))
(jlgg-MakeRotatedDimension pnt p1 (polar pnt Ang 0.01) "")
(jlgg-SSToList ssPoints)
);c.cond
(princ)
(princ)
regards.
