LISP for creating sheets in Autocad
lastorderly
Observer Observer
lastorderly
Observer
Observer
I used to work with a Windows version of AutoCAD and employed a LISP file to create layouts. This file allows creating layouts of formats such as A2, A3, etc., from blocks of the corresponding size.
Now that I’ve switched to the macOS version, the original LISP file no longer works. Could you please advise if it’s possible to adapt the script for macOS or suggest any alternative solutions?
Attached is the original LISP file. It is invoked using the “AL” command. After activation, you select the block with the frames from which the script will determine the width and height. Then, you select the blocks with the frames that will be used to create the layouts. After that, there is an option to delete the existing layouts (or not) and specify the starting number for the new layouts.
pendean
Community Legend
Community Legend
MAC variants cannot use some of the VLAX content in that LISP, or a complete rewrite is needed.
Can you translate the prompts into English? I see nothing but icons and such, so I have no idea how this all works or what the entries even mean
; Óêàçàòåëü ïðèëîæåíèÿ
; Óêàçàòåëü àêòèâíîãî äîêóìåíòà
; Óêàçàòåëü ïðîñòðàíñòâà ìîäåëè
and so on.
lastorderly
Observer
Observer
These are comments of the script developer in Russian, they have Windows-1251 encoding:
Добавить слои в пространстве листов / Add layers in paper space
Загрузка библиотеки ActiveX / Load ActiveX library
Переход на модельный лист / Switch to the model tab
Инициализация с ожидаемым типом данных / Initialize with expected data type
Получение приложения AutoCAD / Retrieve AutoCAD application
Получение активного документа / Retrieve the active document
Получение пространства модели / Retrieve model space
Получение настроек отображения AutoCAD / Retrieve AutoCAD display preferences
Запрос имени слоя для фильтрации объектов / Prompt for layer name to filter objects
Выбор объекта для создания рамки / Select an object to create a frame
Определение слоя объекта / Determine the object's layer
Получение списка объектов на слое / Retrieve a list of objects on the layer
Получение количества объектов на слое / Retrieve the count of objects on the layer
Запрос масштаба / Prompt for scale
Проверка на динамический блок / Check if the object is a dynamic block
Получение габаритного контейнера динамического блока / Retrieve bounding box of the dynamic block
Получение габаритного контейнера обычного объекта / Retrieve bounding box of a regular object
Извлечение координат объектов / Extract object coordinates
Сортировка объектов по координатам X или Y / Sort objects by X or Y coordinates
Проверка включенности автоматического создания видовых экранов / Check if automatic viewport creation is enabled
Отключение автоматического создания видовых экранов / Disable automatic viewport creation
Запрос на удаление всех листов / Prompt for deleting all layouts
Удаление всех листов, кроме модельного / Delete all layouts except the model
Запрос начального номера для листов / Prompt for the starting sheet number
Переименование первого листа / Rename the first layout
Проверка на существование листов с заданными номерами / Check if layouts with the given numbers exist
Уведомление о конфликте номеров листов / Notify about conflicting sheet numbers
Создание нового листа / Create a new layout
Установка текущего листа / Set the current layout
Определение параметров видового экрана / Set viewport parameters
Отображение видового экрана / Display the viewport
Установка модели в пространстве листа / Set the model in paper space
Центровка вида в видовом экране / Center the view in the viewport
Блокировка отображения видового экрана / Lock viewport display
Установка стиля печати для листа / Set the plot style for the layout
Настройка типа печати на листе / Configure the plot type for the layout
Выбор формата бумаги на основе размеров экрана / Select paper size based on screen dimensions
Установка ориентации печати на листе / Set the print orientation on the layout
Масштабирование всего на листе / Zoom all on the layout
Переход на модельный лист после завершения / Switch to the model tab after completion
Функция для нахождения минимального элемента списка / Function to find the minimum element in a list
Функция для нахождения максимального элемента списка / Function to find the maximum element in a list
Функция для извлечения габаритного контейнера динамического блока / Function to extract the bounding box of a dynamic block
Проверка на наличие ошибок при извлечении контейнера / Check for errors while extracting the bounding box
Получение масштабов координат блока / Retrieve block coordinate scales
Применение координат для формирования габаритов блока / Apply coordinates to define block dimensions
paullimapa
Maybe best to invest in Parallels Desktop. Then you can install Windows version of AutoCAD on your Mac and run all the same lisp functions.
Paul Li
IT Specialist
@The Office
