I have a lisp routine which will create a legend of specified lines used in a drawing, but I need some help specifying the spacing between each line of text. I need a specific distance of 0.168 between each line of text. Here is the routine:
(defun C:LEGEND ( / *error* acdoc acobj an co e hs ht i la lst lt p p1 p2 p3 space ss st ro dr)
(vl-load-com)
(setq acObj (vlax-get-acad-object)
acDoc (vla-get-activedocument acObj)
space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace))
(vla-startundomark acDoc)
;;;;;; Error function ;;;;;;;;;
(defun *error* (msg)
(and
msg
(not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*"))
(princ (strcat "\nError: " msg))
(if (and a (not (vlax-erased-p a))) (vla-delete a))
(vla-endundomark acDoc)
(princ)
(setq st (entget (tblobjname "style" (getvar 'textstyle)) '("AcadAnnotative"))
an (member '(1070 . 1) (cdr (member '(1070 . 1) (cadr (assoc -3 st)))))
hs (cdr (assoc 40 st))
ro (angle '(0 0 0) (trans (getvar "UCSXDIR") 0 (trans '(0 0 1) 1 0 T)))
dr (trans '(0 0 1) 1 0 T)
(if
an
(setq ht (/ (if (> hs 0) hs 3.0) (cond ((getvar 'cannoscalevalue)) (1.0))))
(setq ht (* (if (> hs 0) hs 3.0) (getvar 'ltscale)))
(if
(setq ss (ssget))
(progn
(repeat (setq i (sslength ss))
(setq
e (entget (ssname ss (setq i (1- i))))
la (cdr (assoc 8 e))
lt (cdr (assoc 6 e))
co (cdr (assoc 62 e))
(if
(not (member (list la lt co) lst))
(setq lst (cons (list la lt co) lst))
(setq lst (vl-sort lst '(lambda (a b) (< (car a) (car b)))))
(if
(setq p (getpoint "\nSpecify insert point: "))
(foreach x lst
(setq p1 (trans p 1 0)
p2 (trans (polar p 0.0 (* 10 ht)) 1 0)
p3 (trans (polar p 0.0 (* 11 ht)) 1 0)
(entmake
(list
'(0 . "LINE")
(cons 8 (car x))
(cons 10 p1)
(cons 11 p2)
(cons 6 (cond ((cadr x)) ("ByLayer")))
(cons 62 (cond ((caddr x)) (256)))
(vla-put-textalignmentpoint
(vlax-ename->vla-object
(entmakex
(list
'(0 . "TEXT")
(cons 8 (car x))
'(100 . "AcDbText")
(list 10 0 0 0)
(cons 40 ht)
(cons 1 (car x))
(cons 50 ro)
(cons 7 (getvar 'textstyle))
(cons 72 0)
(list 10 0 0 0)
(cons 210 dr)
(cons 73 2)
(vlax-3d-point p3)
(setq p (polar p (/ pi -2.0) (* 2 ht)))
(*error* nil)
(princ)
