Lisp for control dynamic block
Bin2009
Bin2009
I use dynamic blocks show the soil layers, but when the layers too small , all the blocks stuck together, is any way I can control the distance of the line in dynamic block, let them show nicely and readable?
This image “now” show what I got now.
This image “hope” show what I hope can get.
This drawing “block” is the dynamic block.
kajanthangavel
I am not LISP expert.
but I hope this help you.
Select  blocksSelect blocks
Code here...............
(defun LM:setdynpropvalue ( blk prp val )
    (vl-some
       '(lambda ( x )
            (if (= (strcase prp) (strcase (vla-get-propertyname x)))
                (progn
                    (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
                    (cond (val) (t))
                );end_progn
            );end_if
        (vlax-invoke blk 'getdynamicblockproperties)
);end_defun
(defun c:DBA ( / D4 D5 D6 hnd ss b_obj)
(setq D4 10.5
	D5 2
	D6 1)
 (if (setq ss (ssget ":L" '((0 . "INSERT"))))
        (progn
            (repeat (setq i (sslength ss))
                (setq hnd (ssname ss (setq i (1- i))))
				(setq b_obj (vlax-ename->vla-object hnd))
				(LM:setdynpropvalue b_obj "Distance4" D4)
				(LM:setdynpropvalue b_obj "Distance5" D5)
				(LM:setdynpropvalue b_obj "Distance6" D6)
				(setq D4 (- D4 2))
				(setq D5 (+ D5 3))
  (prompt "Missed Try again   ")
);end_defun
Commadnd - DBA
Sea-Haven
Are you aware of the Geotech extension from Autodesk may be useful.
Bin2009
Hello @Kajanthanqavel,
Thank so much, it works great!
I will study your code.
Bin
Bin2009
Hello @Sea-Haven :
Thank for your information, I will look at Geotech extension.
Bin
