Lisp For AutoCAD DWG filename?
leonardo.alvarez4SZJL
Message 1 of 23
I am running AutoCAD Electrical 2022, Windows 10.
Hi Everyone, Is it possible for a LISP to grab attributes and combine them to rename the DWG name itself?. Here is an example.
I have a title block which contains these attributes:
DWG#: 5524D85
Rev: B
Dwg Desc: One Line Diagram
The Lisp Routine would grab these attributes and rename the DWG as follows: 5524D85 (B) One Line Diagram.
Best Regards,
Leo
Replies (22)
Message 21 of 23
3wood
I've updated the file.
Please download from here and try it.
Message 22 of 23
@3wood
You are the man! Thank you!
Best Regards!
Leo
Message 23 of 23
pdelgadillo
Observer
Observer
Thanks for yor work, i've tried to use the code but i just discovered that if the tag and promt have the same value it doesn't work.
I need to modify names of a large number of existing files and can't change promt value one by one.
Can you help me??
Thanks!!
