LISP for arranging blocks and set distance
gSedusak
gSedusak
Hello to everyone. I would need a little help from experts 😄
Some time ago, @Kent1Cooper helped me to write this LISP, so I can arrange large number off different blocks to single line:
From this,
 to this, with just one command.
;|BlocksInRow.lsp [command name: BIR]
; Puts all selected Blocks In a Row, starting at a User-specified location, placing
; them with their insertion points horizontally aligned, with equal-sized gaps
; between their extents in the horizontal direction.
; Space between extents of Blocks is entered by the user.
; Kent Cooper, 7 June 2023
(vl-load-com)
(defun C:BIR (/ ss space nextleft blk blkLL blkUR blkleft blkins)
  ; Check if any blocks are selected on unlocked layers
  (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
    (progn ; If blocks are selected, proceed
      (setq
        nextleft (getpoint "\nLeft edge of first Block at Y-coordinate level of insertion point: ")
        space (getdist "\nEnter the distance between blocks: ") ; Prompt for the distance between blocks
      ); setq
      ; Iterate over each selected block
      (repeat (setq n (sslength ss))
        (setq blk (ssname ss (setq n (1- n))))
        ; Get the bounding box of the block
        (vla-getboundingbox (vlax-ename->vla-object blk) 'minpt 'maxpt)
        ; Extracting the coordinates of the lower-left corner and upper-right corner of the block
        (setq
          blkLL (vlax-safearray->list minpt)
          blkUR (vlax-safearray->list maxpt)
          blkleft (list (car blkLL) (caddr (assoc 10 (entget blk)))); left edge at Y coord. of ins. pt.
        ); setq
        ; Move the block to the next position
        (command "_.move" blk "" "_non" blkleft "_non" nextleft)
        ; Calculate the next left edge position for the next block
        (setq nextleft (polar nextleft 0 (+ (- (car blkUR) (car blkLL)) space)))
      ); repeat
    ); progn
  ); if
  ; Print the result
  (prin1)
); defun
Thank you for that, that really was live safer, because sometimes i have 1000 blocks, that I need to arrange them in rows.
But now i got a new problem. Now I am using attributes and because off the attributes, the line doesn't get to the next block any more:
So my idea is, that i make all my blocks dynamic and make my connecting line stretching:
Now, I would need a LISP, that would arrange selected blocks to row and will connect my line to next block. My parameter for extending connecting line is "Distance1".
And I have a Visibility parameter to, so that original block doesn't have connecting line, then I switch visibility to use block for row drawing. But I will just make sure, that all blocks have same Visibility parameters and change them by hand.
I only made one block for now, but after I have a solution, I will make sure to make all my blocks with right parameters.
Thanks in advance, Gašper
please upload sample dwg
Kent1Cooper
Here's a wacky idea:  Define the Attribute as starting with a default of %%O [that's a letter "O", not a zero], which is the trigger for OVERSCORE, and a space to pull the rest of the content rightward a little.  Here, I did that, and for each Attribute value, retained the "%%O " beginning, and added a space at the end.  Then the regular BIR command, unaltered, with the spacing-between at zero, turned the upper part of this image to the lower part.
Then the "line" is just the overscoring of the Attribute text, self-adjusting to the length of that, and you don't need an actual Line nor the dynamic business at all.  You just have to have in mind to keep the %%O Overscoring trigger and the spaces before and after the actual content [or don't keep the spaces, if you don't mind the text crunching up closer to other parts].
It does take a little care in positioning the Attribute so that the end of its overscoring lands in the right place -- you can't Osnap to that, even if the justification is Top Left.
Kent Cooper, AIA
gSedusak
Thank you both for a quick replay.
@7598165 Example file uploaded. The "Original placement"  is exactly how I get blocks arranged on a floor plan. The first result is made with LISP that is attached in this post. Wanted result is copied first result and then fixed connections with hand.
@Kent1Cooper This really is wacky idea 😀. I tried your solution and it worked really good.
But I really gave wrong example, how things look in reality. Unfortionally blocks are pre-designed and have attributes on both side and on the top center and so on. I made an example drawing, to make it more clear. This are most used blocks, in my library it is around 100 of them, different shapes and with different attributes.
Best regards, Gašper
