lisp file for redefining blocks and exporting attributes
m.meuris
m.meuris
Hi
I would like to combine redefine 3 named blocks and synchronise attributes and export attributes to a text file into one lisp file.
for automatisation of as built drawings .
so that i can batch process the lisp
I found examples for redefine , and for attout but would like to combine it.
block names :PARTLIST1 , PARTLIST2, Tittelblock standaard
please help
thank you
m.meuris
Ifound out-att on this forum and combined it with what i had ...
My follow up question :
I would like to script this , so that there is no need for manual interaction . is that possible ?
can i add a publish to this ?
or print to pdf ?
Or is it simpler to batchplot the files after saving
(defun c:out-att ()
(load "attout")
(command "-insert" "PARTLIST1=")(COMMAND)
(command "-insert" "PARTLIST2=")(COMMAND)
(command"attsync""n""PARTLIST1")
(command"attsync""n""PARTLIST2")
(setq fna (strcat (getvar "dwgprefix")
(acet-filename-path-remove (acet-filename-ext-remove (getvar "dwgname")))
".txt"
(setq ss (ssget "X" '((0 . "INSERT") (66 . 1))))
(bns_attout fna ss)
(command "qsave")
Sea-Haven
Google "print to pdf lisp Autocad" so many examples.
m.meuris
still wandering what is best practice : print function in the lisp
or seperate use of publish for batch plotting.
I need to process a lot of drawings , all with a page setup with printstyle included ,
A4->A0 depending on the layout.
once the batch is done I was thinking of making a button with the command for the lisp followed by publish, so that we always create a text file and a pdf .
Sea-Haven
Google "Maratovich plotting autocad"
Is there a reason for 100  dwgs rather than 1 - 2 using layouts.
m.meuris
For the automisation of As Built drawings with charge numbers we want our blocks to have the additional charge number attribute and a pdf to be send with the attout file to our quality department, going back 2 years in time for all drawings of the last 2 years.
Sea-Haven
As this sounds like an archiving problem and not must do right now ie have a little bit of time, then sort of easy just do a script opens dwg, atts exported then plot pdf.
Inside the plot pdf can read title block etc so print as correct size else just do all to 1 size and use Fit. AS your metric A3 would be ideal size as a 1 size fits all.
