LISP - export coordinates to XML
Message 1 of 10
Hi !
hi !
my list command shows me :
LWPOLYLINE Layer: "0"
Space: Model space
Handle = 2a4
Closed
Constant width 0.0000
area 4322.9452
perimeter 443.9655
at point X= 27.8339 Y= 47.2804 Z= 0.0000
at point X= 218.0915 Y= 108.9413 Z= 0.0000
at point X= 223.3759 Y= 91.6231 Z= 0.0000
at point X= 34.6587 Y= 23.1296 Z= 0.0000
i want to export just the coordinates , but in this format :
<Points>
<POINTID>1</POINTID>
<IMMOVABLEID>1</IMMOVABLEID>
<NO>1</NO>
<X>27.8339</X>
<Y>47.2804</Y>
</Points>
<Points>
<POINTID>2</POINTID>
<NO>2</NO>
<X>218.0915</X>
<Y>108.9413</Y>
</Points>
<Points>
<POINTID>3</POINTID>
<NO>3</NO>
<X>223.3759</X>
<Y>491.6231</Y>
</Points>
<Points>
<POINTID>4</POINTID>
<NO>4</NO>
<X>34.6587</X>
<Y>23.1296</Y>
</Points>
if it has 3 points , to export 3 points ... if it has 50 points , to export 50 points , starting with point 1 on each export.
can it be done to ask me where to export it ?
i attached a file with the coordinates and a file without the coordinates ...
Thatks !
Replies (9)
Message 2 of 10
dgorsman
Should be entirely possible.  You might want to make a couple of changes though, if the XML content will allow it.  Consider changing the <Points> element name to a singular Point for clarity.  And start the vertex numbering at 0 rather than 1, which will help with later processing.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 3 of 10
ВeekeeCZ
This should work. Since I have no experience with XML structure consider @dgorsman's notes.
(vl-load-com)
(defun c:PlineToXml (/ *error* :ReadFile :XmlPoint xml f vrs i)
    (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if f (close f))
    (princ))
  (defun :ReadFile (name / lst)
    (if (setq f (open name "r"))
      (while (setq l (read-line f))
        (setq lst (cons l lst))))
    (if f (close f))
    (reverse lst))
  (defun :XmlPoint (p i /)
    (list "  <Points>"
          (strcat "    <POINTID>" i "</POINTID>")
          (strcat "    <IMMOVABLEID>1</IMMOVABLEID>")
          (strcat "    <NO>" i "</NO>")
          (strcat "    <X>" (rtos (car  p) 2 3 ) "</X>")
          (strcat "    <Y>" (rtos (cadr p) 2 3 ) "</Y>")
          "  </Points>"))
  (or *p2x-path*
      (setq *p2x-path* (getvar 'DWGPREFIX)))
  (if (and (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))
           (setq name (getfiled "Select XML file: " *p2x-path* "cgxml" 4))
           (setq *p2x-path* (strcat (vl-filename-directory name) "\\"))
           (setq xml (:ReadFile name))
           (or (not (member "  <Points>" xml))
               (alert "Error: File already includes points."))
           (setq vrs (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (ssname ss 0)))))
           (setq f (open name "w"))
           (setq i 0) ; initial number is i+1
    (progn
      (while (and (car xml)
                  (/= (car xml) "  <Registration>")
        (write-line (car xml) f)
        (setq xml (cdr xml)))
      (foreach vrt vrs
        (foreach l (:XmlPoint vrt (itoa (setq i (1+ i))))
          (write-line l f)))
      (while (car xml)
      (close f)
  (princ)
Also HERE are some guidelines how to run LISP in case you don't know already.
Message 4 of 10
dgorsman
Thanks @ВeekeeCZ .
While it's possible to manually create XML using text strings I *highly* recommend using VLISP to access the MSXML2.DOMDOCUMENT.6.0 DOM.  It's not much more work, and guarantees properly formed XML.  It also makes accessing the elements much easier.
Message 5 of 10
Thank you !!!
You are the best !
Message 6 of 10
@BeekeeCZ , need something more ...
It works perfect if i don`t have points in my XML file.
if i have points in my xml , it gives me an error ... and in some files it puts the text that i want after the </CGXML> line (and it does not work). i uploaded a file that suffers that ...
can you modify it a little ?
i mean :
1) if the XML file has points , remove all points and insert the points after that
2) insert the points on line 2 ( after <CGXML> line)
first one is the harder job ... i think to myself ...
What can i do for you ?
you really helped me untill now !
if you do this modifications i really want to help you somehow !
Message 7 of 10
ВeekeeCZ
Not really sure if I understood you correctly, but try the modified code.
The key tag is <registration>. The points are always placed before it. It there is the <points> tag already, all lines from that to <registration> are removed.
If the above rules wouldn't be enough and it should get more complicated, then it might be the right time to move to a more appropriate and comprehensive solution mentioned by @dgorsman .
BTW you should try to read the code and get understand the principle to be able to do at least minor adjustments by your own.
Greetings to Romania!
(vl-load-com)
    (if f (close f))
    (princ))
    (if f (close f))
    (reverse lst))
    (list "  <Points>"
          "  </Points>"))
  (or *p2x-path*
    (progn
                  (not (wcmatch (strcase (car xml) T) "*<registration>*,*<points>*"))) 	; write back all until <registration> or <point*> tag reached
      (foreach vrt vrs									; write all new points
          (write-line l f)))
      (while (and (car xml)								; skip all current <points> if there are any (untill <registration> tag reached)
                  (not (wcmatch (strcase (car xml) T) "*<registration>*")))
      (while (car xml)									; write all the rest.
      (close f)
  (princ)
Message 8 of 10
i have another problem ...
there are some files that contains vital information between the last </POINTS and <REGISTRATION>
The problem is that it deletes that 😞
before it looks like this :
<Points>
<POINTID>30013</POINTID>
<IMMOVABLEID>10001</IMMOVABLEID>
<NO>30013</NO>
<X>689470.514805319</X>
<Y>476069.298022253</Y>
</Points>
<Address>
<ADDRESSID>10001</ADDRESSID>
<SIRSUP>75515</SIRSUP>
<SIRUTA></SIRUTA>
<INTRAVILAN>false</INTRAVILAN>
<DISTRICTTYPE></DISTRICTTYPE>
<DISTRICTNAME></DISTRICTNAME>
<STREETTYPE></STREETTYPE>
<STREETNAME></STREETNAME>
<POSTALNUMBER></POSTALNUMBER>
<BLOCK></BLOCK>
<ENTRY></ENTRY>
<FLOOR></FLOOR>
<APNO></APNO>
<ZIPCODE></ZIPCODE>
<DESCRIPTION></DESCRIPTION>
<SECTION></SECTION>
</Address>
<Parcel>
<PARCELID>10002</PARCELID>
<LANDID>10001</LANDID>
<NUMBER>1</NUMBER>
<MEASUREDAREA>240232.0</MEASUREDAREA>
<USECATEGORY>P</USECATEGORY>
<TITLENO></TITLENO>
<LANDPLOTNO>13/1</LANDPLOTNO>
<PARCELNO>83/4</PARCELNO>
<PAPERCADNO></PAPERCADNO>
<PAPERLBNO></PAPERLBNO>
<TOPONO></TOPONO>
<CADGENNO></CADGENNO>
</Parcel>
<RegistrationXEntity>
<REGISTRATIONXENTITYID>10001</REGISTRATIONXENTITYID>
<REGISTRATIONID>10001</REGISTRATIONID>
</RegistrationXEntity>
<Registration>
<REGISTRATIONTYPE>INTAB</REGISTRATIONTYPE>
<RIGHTTYPE>PROPRIETATE</RIGHTTYPE>
<DEEDID>10001</DEEDID>
<TITLE>LEGE</TITLE>
<QUOTATYPE>FRACTION_QUOTA</QUOTATYPE>
<INITIALQUOTA>1/1</INITIALQUOTA>
<ACTUALQUOTA>1/1</ACTUALQUOTA>
<VALUECURRENCY></VALUECURRENCY>
<VALUEAMOUNT></VALUEAMOUNT>
<COMMENTS></COMMENTS>
<LBPARTNO>2</LBPARTNO>
<POSITION>1</POSITION>
<APPNO>4858</APPNO>
<APPDATE>2018-03-29T00:00:00.000+03:00</APPDATE>
</Registration>
<Deed>
<DEEDNUMBER>ordinul nr. 749</DEEDNUMBER>
<DEEDDATE>2011-06-29T00:00:00.000+03:00</DEEDDATE>
<DEEDTYPE>ACT_NORMATIV</DEEDTYPE>
<AUTHORITY>INSTITUTIA PREFECTULUI JUDETUL GALATI</AUTHORITY>
<FILEID>0</FILEID>
</Deed>
and after :
<Points>
<NO>30013</NO>
</Points>
<Registration>
<TITLE>LEGE</TITLE>
<APPNO>4858</APPNO>
</Registration>
<Deed>
<FILEID>0</FILEID>
</Deed>
i have to change that condition :
(progn
(write-line l f)))
and instead of deleting all from point to registration , i just want to delete all the points.
Can you do that for me ?
Please ?
Message 9 of 10
bcddss
(vl-load-com)
    (if f (close f))
    (princ))
    (if f (close f))
    (reverse lst))
    (list "  <Points>"
          (strcat "    <X>" (rtos (car  p) 2 8 ) "</X>")
          (strcat "    <Y>" (rtos (cadr p) 2 8 ) "</Y>")
          "  </Points>"))
  (or *p2x-path*
    (progn
                  (not (wcmatch (strcase (car xml) T) "*<points>*"))) 	; write back all until <registration> or <point*> tag reached
         (write-line l f)))
      (while (and (car xml)								; skip all current <points> if there are any (untill <address> tag reached)
            (not (wcmatch (strcase (car xml) T) "*<address>*")))
      (close f)
  (princ)
 Try this! Modify only line with <address>
Ahags
Message 10 of 10
bcddss
One more thing is to insert last point the point nr 1, to complete the CGXML. Please help!
Ahags
