Lisp explode all Except Line
Edwin.Saez
Advisor Advisor
Edwin.Saez
hi everyone!
Someone will have a lisp, that works just like the command "explode", but does not ask for a selection, but when running the command explode everything. It should also exclude exploiting the lines.
This code does what I need, but does not exclude the lines, Could someone change it?
(setvar "QAFLAGS" 1) (command "_.explode" (ssget "_X") "") (setvar "QAFLAGS" 0)
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
Kent1Cooper
@Edwin.Saez.Jamanca wrote:
... works just like the command "explode", but does not ask for a selection, but when running the command explode everything. It should also exclude exploiting the lines.
Another way:
(initcommandversion 2)
(command "_.explode" "_all" "")
BUT what do you mean by excluding the Lines?  They can't be Exploded anyway, so the above just counts them as among the things that it couldn't Explode [along with other kinds of things, such as plain Text, Circles, etc.].  Do you mean some other  kind of object(s), such as Polylines?  If so:
(command "_.explode" (ssget "_X" '((0 . "~*POLYLINE"))) "")
Kent Cooper, AIA
Edwin.Saez
@Kent1Cooper,
Thanks for the help, if it is working well.
I wanted to ask you if it could be included in a single line of code, excluding polylines and hatchs. it's possible?
Edwin Saez
Kent1Cooper
That would require a "logical grouping" of things that are not Polylines AND are not Hatches.  Read about logical groupings in (ssget) filter lists in Help.
(command "_.explode" (ssget "_X" '((-4 . "<AND") (0 . "~*POLYLINE") (0 . "~HATCH") (-4 . "AND>"))) "")
Kent Cooper, AIA
Ranjit_Singh
I wanted to ask you if it could be included in a single line of code, excluding polylines and hatchs..........
(ssget "_x" '((-4 . "<not") (0 . "*polyline,hatch") (-4 . "not>"))
