I dont even know to describe this. I am trying to write a lisp for auto dim, in which i will pre define a variable for dimesion line location but the defined variable is not always be consider when the lisp is excuted
(defun c:D2 ()
(while (not (equal (setq ent (entsel)) nil))
(progn
(setq dxf (entget (car ent)))
(setq start (cdr (assoc 10 dxf)))
(setq end (cdr (assoc 11 dxf)))
(command "dimaligned" start end)
(princ)
(defun c:d11 ()
(setq d11 (getreal "nhap khoang cach"))
(defun c:d1 ()
(setq ss (ssget)
len (sslength ss)
i 0
(if (not (boundp 'd11))
(setq D11 40)
(repeat len
(progn
(setq ent (ssname ss i)
entd (entget ent)
i (+ 1 i)
(if (eq (cdr (assoc 0 entd)) ' "LINE")
(progn
(setq start (cdr (assoc 10 entd))
end (cdr (assoc 11 entd))
start
end
(trans (polar start (+ (angle start end) (/ pi 2)) d11) 0 1)
(command "mirror" ent "" (cdr (assoc 13 entd)) (cdr (assoc 14 entd)) "Y")
