LISP error
LISP error
IkaroFalcao
LISP error
IkaroFalcao
Hey Guys, whats up?
Well I am developing a lisp to automatically create a list of the blocks that I have in the drawing, so the client know its meaning.
Everything was workking just fine but suddenly a problem happened, the lisp is inserting two different blocks in the same insert point.
As the picture:
But that is how it should look(and was looking):
Here is the code that I developed:
Thank you in andvance.
ВeekeeCZ
Must say it's very practical way how to share the code. Personally I would prefer if you post it as a text.
Anyway, it looks like you are not turning the osnap off. Use "_none" in front of each point inside of (command) function.
(command "_.insert" pathname "_none" pt ....)
hmsilva
Hi Ikaro,
in addition to BeeKee's advices, use the "_NON" in the insert command and next time please post your code as text....It will be much easier to provide some help, I would suggest also to test the return from 'getpoint' before using it as an argumente for the next functions, and the no need to repeat the same bit of code numerous times...
Untested...
 ; test a returned valid point from user input
(if (setq ponto1 (getpoint "\nInforme onde inserir a legenda... "))
   (progn
      (setq insercao 0
            dist     0.5
            lst      '("Quadro de Luz e ou Tomadas" "Quadro de Força" "Quadro Distribuição Lógica ou Interfone" "e todos os outros blocos...")
      (command "_.insert" "C:/PJ/Legenda/Titulo(legenda).dwg" "_S" 1 "_R" 0 "_NON" ponto1)
      (foreach blk lst
         (if (tblsearch "BLOCK" blk)
            (progn
               (setq insercao (1+ insercao)
                     ponto2   (polar ponto1 (* 1.5 pi) (* dist insercao))
               (command "_.insert" (strcat "C:/PJ/Legenda/" blk "(legenda)") "_S" 1 "_R" 0 "_NON" ponto2)
Hope this helps,
Henrique
IkaroFalcao
Thank you guys, that was the problem.
Next time I will put the code as text, sorry about that.
