LISP Error
LISP Error
Cudal
LISP Error
Cudal
I have AutoCAD LT. I use to use this lisp "https://www.lee-mac.com/ptmanager.html", however when I change laptop, I am now getting error. anyone have solution for the error. Thanks
paullimapa
I believe this app is designed to reference AutoCAD support files named for AutoCAD and not AutoCAD LT. A similar thread on this error can be found here when running using Briscad:
https://forum.bricsys.com/discussion/24691/ptmanager-lisp-dcl
Perhaps you may try contacting the author on this app with the correct link here:
https://lee-mac.com/ptmanager.html
Paul Li
IT Specialist
@The Office
Cudal
Thank you Paul. I was able to solve it after reading the link you provided. I check the code and it is looking for ACAD.PAT since I am using AutoCAD LT I don't have ACAD.PAT but ACADLT.PAT. so I just copy the file and rename to ACAD.PAT and now the lisp is working. Thanks
paullimapa
Glad that worked out for you. Or you may want to try changing the code to now look for “acadlt.pat”
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@Cudal wrote:
....so I just copy the file and rename to ACAD.PAT and now the lisp is working. Thanks
Would it not have just been easier to edit the LISP code for ACADLT.PAT or did that not work?
paullimapa
Like minds think alike
Paul Li
IT Specialist
@The Office
Sea-Haven
I use Acad & Bricscad so to write one version can do a simple check which cad program are you running so use an if to set the correct pat file. A earlier version of Bricscad has no "REVERSE" but can used pedit "Reverse"
Use (vlax-product-key) can look for which CAD is being used.
