Announcements
Lisp error quit/exit abort system variables have been reset
Nabilaputridania
Community Visitor
Nabilaputridania
Community Visitor
Community Visitor
i cannot use adarray lisp
can you guys help me
;;;Cadalyst AutoLISP Solutions	July 2007	ALSPSOL0707.ZIP / ADARRAY.LSP 	(c) Tony Hotchkiss
(defun err (s)
  (if (= s "Function cancelled")
    (princ "\nADARRAY - cancelled: ")
    (progn (princ "\nADARRAY - Error: ")
	   (princ s)
	   (terpri)
    ) ;_ progn
  ) ;_ end of if
  (resetting)
  (princ "SYSTEM VARIABLES have been reset\n")
  (princ)
) ;_ end of err
(defun setv (systvar newval)
  (setq x (read (strcat systvar "1")))
  (set x (getvar systvar))
  (setvar systvar newval)
) ;_ end of setv
(defun setting ()
  (setq oerr *error*)
  (setq *error* err)
  (setv "CMDECHO" 0)
  (setv "BLIPMODE" 0)
  (setv "OSMODE" 0)
  (setv "CLAYER" (getvar "CLAYER"))
) ;_ end of setting
(defun rsetv (systvar)
  (setvar systvar (eval x))
) ;_ end of rsetv
(defun resetting ()
  (rsetv "CMDECHO")
  (rsetv "BLIPMODE")
  (rsetv "OSMODE")
  (rsetv "CLAYER")
  (setq *error* oerr)
) ;_ end of resetting
(defun adarray ()
  (vl-load-com)
  (setq	*thisdrawing* (vla-get-activedocument
			(vlax-get-acad-object)
		      ) ;_ end of vla-get-activedocument
	*modelspace*  (vla-get-ModelSpace *thisdrawing*)
  ) ;_ end of setq
  (setq	bnameindex nil)
  (setq doit 4)
  (setq ad_id (load_dialog "adarray.dcl"))
  (while (>= doit 2)
    (if	(not (new_dialog "adarray" ad_id))
      (exit)
    ) ;_ end of if
    (init-array)
    (action_tile "bname" "(setq bnameindex (atoi $value))")
    (action_tile "row" "(setq *rowdist* (atof $value))")
    (action_tile "col" "(setq *coldist* (atof $value))")
    (action_tile "pick" "(done_dialog 3)")
    (action_tile
      "accept"
      "(get-adarray-data) (done_dialog 1)"
    ) ;_ end of action_tile
    (setq doit (start_dialog))
    (cond
      ((= doit 1)
       (do-array)
      ((= doit 3)
       (setq *point0* (getpoint "\nPick a point: "))
    ) ;_ end of cond
  ) ;_ end of while
  (unload_dialog ad_id)
) ;_ end-of adarray
(defun init-array ()
  (setq	blks (vla-get-blocks *thisdrawing*)
	num  (vla-get-Count blks)
	*blknames* nil
	i 1
  ) ;_ end of setq
  (repeat (- num 2)
    (setq blk	   (vla-item blks (setq i (1+ i)))
	  bname	   (vla-get-Name blk)
	  *blknames* (append *blknames* (list bname))
    ) ;_ end of setq
  ) ;_ end of repeat
  (if *blknames*
    (progn
      (start_list "bname")
      (mapcar 'add_list *blknames*)
      (end_list)
    ) ;_ end of progn
  ) ;_ end of if
  (if bnameindex
    (set_tile "bname" (itoa bnameindex))
  ) ;_ end of if
  (if *rowdist*
    (set_tile "row" (rtos *rowdist*))
    (set_tile "row" "2")
  ) ;_ end of if
  (if *coldist*
    (set_tile "col" (rtos *coldist*))
    (set_tile "col" "2")
  ) ;_ end of if
) ;_ end of init-array
(defun get-adarray-data ()
  (setq bnameindex (atoi (get_tile "bname")))
  (setq *bname* (nth bnameindex *blknames*))
  (setq *rowdist* (atoi (get_tile "row")))
  (setq *coldist* (atoi (get_tile "col")))
) ;_ end-of get-tool-data
(defun do-array ()
  (setq lyr "arr-hatch")
  (vl-cmdf "Layer" "M" lyr "C" "green" "" "")
  (vl-cmdf "-Hatch" *point0* "P" "U" "0.0" *rowdist* "N" "")
  (vl-cmdf "Explode" (entlast))
  (setq	ss     (ssget "X"
		      (list '(0 . "LINE")
			    (cons 8 lyr)
		      ) ;_ end of list
	       ) ;_ end of ssget
	num    (sslength ss)
	i      -1
  ) ;_ end of setq
  (rsetv "CLAYER")
  (repeat num
    (setq en (ssname ss (setq i (1+ i))))
    (vl-cmdf "Measure" en "B" *bname* "Y" *coldist*)
    (entdel en)
  ) ;_ end of repeat
) ;_ end of do-array
(defun c:ad ()
  (setting)
  (adarray)
  (resetting)
  (princ)
) ;_ end of c:ad
(prompt "\nCopyright (c) 2007, Tony Hotchkiss")
(prompt "\nEnter AD to start")
Kent1Cooper
@Nabilaputridania wrote:
i cannot use adarray lisp ....
That's not enough information.  Does the file load?  Does it accept the AD command name?  What happens when you enter the command name?  Does it not put up the dialog box?  If it does, what are you doing in it?  Did you pick a Block name in the dialog box?  Do you have an area established to use it within [it requires a Hatchable area to pick inside]?  Is your Block too big for the area you picked in?  Etc., etc., etc.
Kent Cooper, AIA
