Lisp doesn't work anymore without changing lisp or settings AutoCad 2018
Sandervp
Message 1 of 10
Sandervp
Hello everybody,
I'm using a lisp file which (should) send all the xrefs to the back with draworder. But suddenly it doesn't work anymore.
I've reloaded him in the startup suite but this doesn't work.
It could be because the xref isn't a dwg but a pdf, but I don't know.
Nothing is changed. I didn't change something in the settings from AutoCad, no other lisp is added and there was no software update.
Does anyone know what the reason could be?
Thank you
Sander
Showed command lines after using the command:
"Command: XDR
_.draworder
Select objects: 0 found
Select objects:
Command: _b Unknown command "B". Press F1 for help."
; set all Xref's to back
[code]
(DEFUN c:xdr ( / curent curset newset)
(vl-load-com)
(SETQ newset (SSADD))
(IF (SETQ curset (SSGET "X" '((0 . "INSERT"))))
(WHILE (SETQ curent (SSNAME curset 0))
(SETQ curobj (VLAX-ENAME->VLA-OBJECT curent))
(IF (= T (VLAX-PROPERTY-AVAILABLE-P curobj 'path))
(SSADD curent newset)
(SSDEL curent curset)
(command "_.draworder" newset "" "_b")
[/code]
  (princ)
Replies (9)
Message 2 of 10
dlanorh
@Sandervp wrote:
Hello everybody,
Thank you
Sander
"Command: XDR
_.draworder
Select objects:
[code]
(vl-load-com)
(IF (SETQ curset (SSGET "X" '((0 . "INSERT"))));; (0 . "PDFUNDERLAY")
[/code]
  (princ)
A PDF Underlay is not a block. Try swapping out (0 . "INSERT") with the red code above
I am not one of the robots you're looking for
Message 3 of 10
CADaSchtroumpf
With little change for select and condition. Try this:
	(vl-load-com)
	(IF (SETQ curset (SSGET "_X" '((0 . "INSERT,PDFUNDERLAY"))))
			(IF (OR (VLAX-PROPERTY-AVAILABLE-P curobj 'Path) (eq "AcDbPdfReference" (VLAX-GET-PROPERTY curobj 'ObjectName)))
	(princ)
Message 4 of 10
ronjonp
You might just need to check that 'newset' exists before passing it to the draworder command:
(defun c:xdr (/ curent curset newset)
  (vl-load-com)
  (setq newset (ssadd))
  (if (setq curset (ssget "X" '((0 . "INSERT"))))
    (while (setq curent (ssname curset 0))
      (setq curobj (vlax-ename->vla-object curent))
      (if (= t (vlax-property-available-p curobj 'path))
	(ssadd curent newset)
      (ssdel curent curset)
  (if newset (command "_.draworder" newset "" "_b"))
  (princ)
Message 5 of 10
john.uhden
Um, newset exists by virtue of
Bur it may be empty, so it would be better to
(if (> (sslength newset) 0) ...)
John F. Uhden
Message 6 of 10
Sandervp
Thank you!
The lisp is working again.
But I still doesn't understand why it suddenly didn't work anymore.
Message 7 of 10
CADaSchtroumpf
@Sandervp  a écrit :
Thank you!
You say:
Yes it's the cause; you don't select PDFUNDERLAY in your code and the PDFUnderLay haven't the property 'Path
Message 8 of 10
CADaSchtroumpf
And if you want to make the code more reliable, the remark from john.uhden is relevant.
Replace
by
(if (not (zerop (sslength newset))) (command "_.draworder" newset "" "_b"))
Message 9 of 10
ronjonp
Very true .. perhaps something like this 🙂
(defun c:xdr (/ a b)
  ;; RJP » 2020-01-13
  (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (and (= -1 (vlax-get b 'isxref)) (setq a (cons (strcat (vla-get-name b) ",") a)))
  (if (setq b (ssget "_X"
		     (list '(-4 . "<OR")
			   '(0 . "PDFUNDERLAY")
			   '(-4 . "<AND")
			   '(0 . "INSERT")
			   (cons 2 (apply 'strcat a))
			   '(-4 . "AND>")
			   '(-4 . "OR>")
    (progn (setvar 'cmdecho 0) (command "_.draworder" b "" "_b") (setvar 'cmdecho 1))
    (print "No xrefs or PDF Underlays found in drawing!")
  (princ)
(vl-load-com)
*Added PDF Underlay to filter
Message 10 of 10
john.uhden
That looks workable, but I am concerned about your yellow smiling face. I
suggest you see your doctor regarding jaundice. 😕
John F. Uhden
