LISP code automate set of Autocad comment or process
ajithsingh18
ajithsingh18
I have a set of processes that I need to automate using LISP. (Scale uniformity to yes, Unit precision to 0.00, Purge all checked items , Zoom extent the drawing)
To open a drawing file from a folder, navigate to the desired folder and locate the file. Then, select the file to open it. To access the block editor, choose the "current drawing" option. Once inside the block editor, set the block property scale uniformity to "YES". Furthermore, please set the unit precision to two decimal places in order to ensure accurate measurements. After that, kindly save and close the block editor page. Next, proceed to purge the drawing sheet purge all checked items and zoom to the extent of the drawing. Finally, save and close the drawing file.
paullimapa
I've attached Block_Scale_Uniform.lsp which will take care of current dwg scale uniform setting
You'll need to save this in one of AutoCAD Support File Search Path & Trusted Locations: (Options>Files).
Then to load it at command line enter:
(load"Block_Scale_Uniform")
and run it by entering command:
Block_Scale_Uniform
As for unit precision again at command line enter:
_.LUPREC 2
For purging everything at command line enter:
_.-PURGE _ALL * _No
Lastly:
_.ZOOM _E
Now to run the above on all drawings in a folder you can use Lee Mac's Script Writer:
Script Writer | Lee Mac Programming (lee-mac.com)
On Script Line enter sequence as provided above:
_.Open *file* (load"Block_Scale_Uniform") Block_Scale_Uniform _.LUPREC 2 _.-PURGE _ALL * _No _.ZOOM _E _.Qsave _.Close
Paul Li
IT Specialist
@The Office
