Lisp - Closed Polyline
Message 1 of 9
Hello
is there any lisp that checks if inside a closed polyline there is a label: text or mtext, and if it is not, it somehow marks this polyline, for example by changing its color?
Text, mtext is on the specified layer
Thanks for any help
Replies (8)
Message 2 of 9
doaiena
This will get you started. Adjust it as you see fit.
(defun c:test ( / ss ctr ent)
(if (setq ss (ssget "_X" '((0 . "LWPOLYLINE") (70 . 1))))
(progn
(setq ctr 0)
(repeat (sslength ss)
(setq ent (ssname ss ctr))
(if (ssget "_WP" (mapcar 'cdr (vl-remove-if-not '(lambda (dxf) (= (car dxf) 10)) (entget ent))) '((0 . "TEXT,MTEXT")))
(command "_chprop" ent "" "_C" "1" "")
(setq ctr (1+ ctr))
);repeat
));if ss
(princ)
);defun
Message 3 of 9
This is almost what I mean.
I have attached a drawing to show what I mean.
Well, text 1365/61 is inside a closed polyline. The text insertion point is inside a closed polyline because the text itself extends beyond the boundaries. If the text insertion point is inside a closed polyline, it also tells me that the text is inside.
Edit: Text insertion point is outside of closed polyline. But I would like Lisp mark closed polyline when center of text was inside closed polyline
Message 4 of 9
doaiena
In that case, change this:
to this:
(ssget "_CP" (mapcar 'cdr (vl-remove-if-not '(lambda (dxf) (= (car dxf) 10)) (entget ent))) '((0 . "TEXT,MTEXT")))
Message 5 of 9
john.uhden
Of course you realize that doesn't account for bulged segments.
You would have more accurate results by extracting points at a tight interval around the length of its perimeter, but even that would not be 100% accurate, but maybe good enough for the OP's purpose.
Then again you might improve the performance by extracting additional points only along bulged segments.
The subject of determining if a point is inside or outside or on a polyline has been discussed here at length for decades.  Search for "@inside revisited."  Maybe I found it...  here
John F. Uhden
Message 6 of 9
doaiena
Yes @john.uhden, you are correct. The OP's definition of the problem was vague, so i wrote a skeleton function which would give him some direction (if he is familiar with autolisp). If he comes back and posts a detailed definition on what functionality he is seeking, there may be a completely different solution than the one i proposed.
Message 7 of 9
It almost solved my problem, but maybe my problem was imprecise. My point was to check if the text, and rather the text insertion point, is inside a closed polyline. It doesn't matter to me that the text passes after the polylines. the question is whether the insertion point is inside.
edit: as the insertion point I understand the middle of the text
Message 8 of 9
Kent1Cooper
Those are mutually contradictory.  Which condition should result in the Polyline being marked?
There are several threads you can Search for in this Forum about determining whether something is inside a Polyline.  I expect in this case the CP selection will be needed, and then Text/Mtext is found, its insertion point determined, and one of those routines used to check whether it's inside.
Kent Cooper, AIA
Message 9 of 9
sorry for the lack of precision.
this is correct:
