LISP - change length of a rectangle
Cudal
Message 1 of 10
Cudal
I have multiple blocks with rectangle of different length. the width is currently 4" and i want change it to 3.75. can someone create a LISP that will change the width of the rectangle to 3.75. it should move the top line 0.125" down and the bottom line 0.125" up. Thank you
  • Lisp
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Why not create a DYNAMIC BLOCK(s) to use that you can incrementally shrink or lengthen whenever you need it with a click or two?
Message 3 of 10
Cudal
the blocks are already existing. at least two hundred and I need to change them individually
Message 4 of 10
pendean
Community Legend
Community Legend
two hundred different blocks?
Or the one same block, 200 copies, and a very quick REFEDIT (or BEDIT) of one instance will fix them all just like that?
Message 5 of 10
paullimapa
Can you share this dwg?
Paul Li
IT Specialist
@The Office
Message 6 of 10
komondormrex
@Cudal
hey there,
check the following. will change every rectangle lw-polyline width in every block from 4 to 3.75 as per suggested.
(defun c:lessen_rect_block_width_4_025 (/ points coordinates segments width_seg mid_point)
 	(vlax-map-collection (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
 		'(lambda (block) (vlax-map-collection block
 							'(lambda (object) (if (and (= "AcDbPolyline" (vla-get-objectname object))
 													   (minusp (vlax-get object 'closed))
 													   (= 4 (vlax-curve-getendparam object))
 													   (not (setq points nil))
 													   (setq coordinates (vlax-get object 'coordinates))
 													   (not (while coordinates (setq points (append points (list (list (car coordinates) (cadr coordinates))))) (setq coordinates (cddr coordinates))))
 													   (setq segments (mapcar 'list points (append (cdr points) (list (car points)))))
 													   (equal (distance (nth 0 points) (nth 2 points)) (distance (nth 1 points) (nth 3 points)) 1e-6)
 													   (equal (apply 'distance (nth 0 segments)) (apply 'distance (nth 2 segments)) 1e-6)
 													   (equal (apply 'distance (nth 1 segments)) (apply 'distance (nth 3 segments)) 1e-6)
 													   (or (equal 4 (apply 'distance (nth (setq width_seg 0) segments)) 1e-6) (equal 4 (apply 'distance (nth (setq width_seg 1) segments)) 1e-6))
 												   (vlax-put object 'coordinates
 														(apply 'append (apply 'append
 																			   (mapcar '(lambda (segment) (mapcar '(lambda (point) (polar (setq mid_point (mapcar '* '(0.5 0.5)
																			   																						  (mapcar '+ (car segment)
																																									  			 (cadr segment)
 																			   													   		  (angle mid_point point)
 																																   		  1.875
 																												   segment
 					 																	(list (nth width_seg segments) (nth (+ 2 width_seg) segments))
	(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
	(princ)
Message 7 of 10
marko_ribar
@komondormrex
I and I suppose all others have difficulty viewing your posts as your formatting of codes always look far too to the right of code tags... Next time, please take some time to prettify codes as it may help both you and others that are looking at it...
Now I did it for you, but next time, please pay attention to what you post and how does it look like...
(defun c:lessen_rect_block_width_4_025 ( / points coordinates segments width_seg mid_point )
  (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com))
    (function
      (lambda ( block )
          (function
            (lambda ( object )
              (if
                (and
                  (minusp (vlax-get object (quote closed)))
                  (setq coordinates (vlax-get object (quote coordinates)))
                  (not
                    (while coordinates
                  (setq segments (mapcar (function list) points (append (cdr points) (list (car points)))))
                  (equal (apply (function distance) (nth 0 segments)) (apply (function distance) (nth 2 segments)) 1e-6)
                  (equal (apply (function distance) (nth 1 segments)) (apply (function distance) (nth 3 segments)) 1e-6)
                  (or
                    (equal 4 (apply (function distance) (nth (setq width_seg 0) segments)) 1e-6)
                    (equal 4 (apply (function distance) (nth (setq width_seg 1) segments)) 1e-6)
                ) ;_ end and
                (vlax-put object (quote coordinates)
                  (apply (function append)
                      (mapcar
                        (function
                          (lambda ( segment )
                            (mapcar
                              (function
                                (lambda ( point )
                                  (polar (setq mid_point (mapcar (function *) (list 0.5 0.5) (mapcar (function +) (car segment) (cadr segment)))) (angle mid_point point) 1.875)
                              ) segment
                        ) (list (nth width_seg segments) (nth (+ 2 width_seg) segments))
                ) ;_ end then
              ) ;_end if
        ) ;_end vlax-map-collection
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 8 of 10
komondormrex
yeah, i have been pointed to it by @Sea-Haven  back earlier, and i try it my best every other time, but still sh(
Message 9 of 10
Sea-Haven
This shows all the tabs that have been used.
Same thing but replace the tabs with 2 spaces. The indenting is still clear but code does not disappear to the right.
Which indenting method are you using ? Bricscad has a Beautify option which will put in tabs.
Message 10 of 10
komondormrex
@Sea-Haven
it's custom tabs, in my case 4-length and spaces.
@marko_ribar
just curious. why do you prefer function over '? there are people out there doing similar all the way.
