Lisp Calculated Sheet Numbering
Message 1 of 8
Hi All,
I  am attempting to create a field that would calculated the sheet number from the order of the layout tabs. I was able to program a command that would accomplish the calculation, but am struggling to find a way to get it to apply the code to populate title block. The code below is what I was able to come up with to find the sheet number.
(defun C:tabnumber()
(setq acadObj (vlax-get-acad-object))
(setq doc (vla-get-ActiveDocument acadObj))
(setq tempLayout (vla-Item (vla-get-Layouts doc) (getvar "CTAB")))
(vla-get-taborder tempLayout)
Thanks for any help.
Replies (7)
Message 2 of 8
maratovich
How are your numbers created?
Is this text? Or do you use title blocks?
Can you attach the sample?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 8
It retrieves the tab name and then using the tab name (getvar “CTAB”) it gets the number the tab is on the bottom. I don’t have it in a title block or anything but if you put the code in autocad then run it it prints the number in the command bar. I just can’t figure a way to make a dynamic field that will display the number for each for each layout.
Message 4 of 8
dbhunia
Hi
As you asked......
@Anonymous wrote:
Hi All,
From your post what I get...... You want to update the Sheet Number as the Order of Layout Tabs in Title Block.....
Now, while its a Title Block ....... there has an Attribute Tag for Sheet Number (which you want to update).......
If I am right try this.......(change the highlighted field in code)......
(defun C:tabnumber (/ layt_lst lay_list blk_name tag_name layoutname);;Put temp variables
(vl-load-com)
(setq blk_name "BLK_NAME"   ;;Put Titel Block Name in place of "BLK_NAME" as per your drawing
      tag_name "NO" 	    ;;Put Att Tag Name of sheet number in place of "NO" as per your drawing its case sensitive
      l -1
      tab (getvar 'CTAB)
(vlax-for layt (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
	(if (> (vla-get-TabOrder layt) 0)
	    (setq layt_lst (cons (cons (vla-get-TabOrder layt) (vla-get-Name layt)) layt_lst))
(setq layt_lst (vl-sort layt_lst '(lambda (x y) (< (car x) (car y)))))
(foreach layt layt_lst
   (setq layoutname (cons (cdr layt) layoutname))
(setq lay_list (reverse layoutname))
(repeat (length lay_list)
  (setq lay_name (nth (setq l (+ l 1)) lay_list))
  (setvar 'CTAB lay_name)
  (setq ss (ssget "_A" (list '(0 . "INSERT")(cons 2 blk_name)(cons 410 lay_name))))
    (repeat (setq NOS (sslength ss))
	  (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
	    (if (= (vla-get-Name blk) blk_name)
		(progn
		(setq obj (vlax-ename->vla-object (ssname SS (setq NOS (- NOS 1)))))
			(foreach att (vlax-invoke Obj 'GetAttributes)
			  (if (= (vla-get-Tagstring att) tag_name)
			      (progn
				(vla-put-textstring att (+ 1 (vl-position lay_name lay_list)))
(setvar 'CTAB tab)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 5 of 8
ronjonp
If you use sheet set manager for your plots the field %<\AcSm Sheet.Number \f "%tc1">% should work.
Although you still have to number them in sheet set manager.
Message 6 of 8
IT WORKED PERFECTLY!  Thank you so much!
Message 7 of 8
zania.davison
Community Visitor
Community Visitor
This is amazing, thank you. Is there a way to edit the code so that it will autofill the block with "C01, C02, C02" etc as opposed to "1,2,3"
Message 8 of 8
Sea-Haven
Try this
(defun C:tabnumber (/ layt_lst lay_list blk_name tag_name layname);;Put temp variables
(vl-load-com)
(setq blk_name "BLK_NAME"   ;;Put Title Block Name in place of "BLK_NAME" as per your drawing
      tab (getvar 'CTAB)
	(progn
	  (setq lay_name (vla-get-name layt))
      (setq num (vla-get-TabOrder layt))
	  (if (< num 10)
	    (setq strnum (strcat "C0" (rtos num 2 0)))
	    (setq strnum (strcat "C" (rtos num 2 0)))
      (setq ss (ssget "_X" (list '(0 . "INSERT")(cons 2 blk_name)(cons 410 lay_name))))
	  (setq obj (vlax-ename->vla-object (ssname ss 0)))
      (setq atts (vlax-invoke obj 'Getattributes))
        (foreach att atts
	    (if (= (vla-get-tagstring att) tag_name)
	     (vla-put-textstring att strnum)
(setvar 'ctab tab)
(princ)
(C:tabnumber)
