LISP calculate and write in square meters area
Message 1 of 14
hello
Please .at the process.
I'm new at this.
Thanks in advance
Replies (13)
Message 2 of 14
parkr4st
what is units set to?  Meters?
if it is meters then the properties will show area in square meters
plain autocad or other product
Message 3 of 14
john.vellek
Hi @Anonymous,
Please give me more detail on what you are trying to accomplish. There are numerous ways of calculating areas and expressing the results in more than one units format.
You are welcome to attach a sample file if you believe it will help me to better understand.
John Vellek
Message 4 of 14
Patchy
Message 5 of 14
Kent1Cooper
There are routines around to do that.  For example, just from the Cadalyst CAD Tips website, this one, or this other one.
Kent Cooper, AIA
Message 6 of 14
Greetings
I measure structures.
And to calculate the area of the rooms.
Each room is a polygon.
And record it in the table.
Sometimes there are very many and difficult to calculate without mistakes.
Best regards
Message 7 of 14
@Anonymous wrote:
Greetings
Best regards
Another method would be to place FIELDS in a TABLE.  Have those FIELDS watch your polylines.  Have the TABLE add up your FIELDS.
Message 8 of 14
Hello and good evening.
Thank you for your help.
I do not know what is better.
I wanted the table next to the polygon.
Best regards
Message 9 of 14
Greetings
in a second thought.
If it is possible in two places.
1) polygon with a serial number.
2) in the table.
Best regards
Message 10 of 14
Patchy
Arealabel does all that.
Message 11 of 14
Greetings
right
Best regards
Message 12 of 14
Hi thank you for the very useful lisp.
just a quick question how can we change text size of area numbers.
@Patchy wrote:
http://www.lee-mac.com/arealabel.html
Message 13 of 14
ВeekeeCZ
Set autocad's system variable TEXTSIZE. Either from Ribbon/Annotate or use the command-line, type TEXTSIZE.
Message 14 of 14
Thank you so much it works.Smiley Happy
