LISP block sorting routine (by insertion coordinate)
kyle_dean
Message 1 of 13
kyle_dean
I am trying to write a function that will get a selection of blocks, and then return a list of the blocks sorted by insertion x,y (left to right, top to bottom).
(defun c:exp1 (/ ss i lst en)
 (if (setq ss (ssget))
   (progn (repeat (setq i (sslength ss))
    (setq en (ssname ss (setq i (1- i)))
     lst (cons (cons en (cdr (assoc 10 (entget en)))) lst))
    (setq s_lst (vl-sort lst '(lambda (x y) (if (= (car x) (car y)) (> (cadr x) (cadr y)) (< (car x) (car y))))))
 (princ)
 I'm trying to make it so that s_lst is the final sorted list. When I run the script it returns error "bad argument type for compare: <Entity name: 1fa972769b0> <Entity name: 1fa97276a90>". I think it must have something to do with the lambda sorting function but I'm not sure.
I have done some searching and i'm getting pretty close close (I can sort by X coordinate only). See below for working X-coordinate sort.
     (mapcar 'print (vl-sort lst ''((a b) (< (cadr a) (cadr b)))))
 (princ)
Replies (12)
Message 2 of 13
Kent1Cooper
I think BlockSSSort.lsp should be able to do what you want -- available >here<.  [Note that it defines not a command, but a function with arguments -- for what you describe, put in at the command line  (BSSS "T" "L") .]
Kent Cooper, AIA
Message 3 of 13
jtohill
I use the data extraction tools and use a table to do the work for me.
Message 4 of 13
ВeekeeCZ
(cons (cons en pt) lst) will create a list of (e x y z)'s. So then you need (caddr) to sort by Y and (cadr) to sort by X. You are one d short.
    (progn
	      lst (cons (cons en (cdr (assoc 10 (entget en)))) lst)))
      (setq s_lst (vl-sort lst '(lambda (a b) (< (caddr a) (caddr b))))
	    s_lst (vl-sort s_lst '(lambda (a b) (< (cadr a) (cadr b)))))
      (print s_lst)))
  (princ)
Message 5 of 13
kyle_dean
@Kent1Cooper
Thanks for the reply. I downloaded the .lsp and loaded it, but the command returns the following error when i run (BSSS "T" "L"):
bad argument type: consp <Entity name: 19222e22ef0>
Any advice? Because it definitely looks like that code is exactly what I need.
Message 6 of 13
kyle_dean
Thank you very much @ВeekeeCZ This works for me now. I had to modify the code a little bit to make it sort in the order I wanted but the following works now:
(defun c:bsort (/ ss i lst en)
    (progn
      (setq s_lst (vl-sort lst '(lambda (a b) (< (cadr a) (cadr b))))
	    s_lst (vl-sort s_lst '(lambda (a b) (< (caddr b) (caddr a)))))
Basically I just had to flip the order of the sorts around a little to make it go left to right then top to bottom
Message 7 of 13
Kent1Cooper
I'm not sure what that could be.  It works for me the first time, but running it again gives the same error.  I'll have to dig into it tomorrow....
Kent Cooper, AIA
Message 8 of 13
cadffm
Time booster 4U
Argumenttyp: consp
Something is expecting a list - but there isn't. In this case it is function 'cadr' in the last codeline.
Issue: blsort2 is not set as local variable
Solution, add blsort2 to the list of local variables (and offtopic, I would skip the last unnecessary symbol bind)
Sebastian
Message 9 of 13
Sea-Haven
Just a suggestion
(setq ss (ssget))
This can get all sorts of objects as there is no filters to say pick block only
(setq ss (ssget '((0 . "INSERT"))))
If you want multiple blocks then you could pre process say pick blocks Block1 block2 so ssget is now
(setq ss (ssget (list (cons 0 "INSERT")(cons 2 blkstr))))
blkstr is "Block1,Block2"
Message 10 of 13
Kent1Cooper
No in both cases.  It is deliberately bound at the end and not localized, so that you can make use of it afterwards.  The attached explicitly sets it to nil at the front, in case there's one remaining from a prior use, which takes care of it.
Kent Cooper, AIA
Message 11 of 13
kyle_dean
@Sea-Haven Thanks for the tip. I'm still pretty new to LISP so I'm still trying to understand pretty fundamental concepts. Is it possible to use that formatting of the ssget to filter a selection set of objects by layer? Say I draw a selection area in autocad that grabs a lot of objects that i don't want and only want to continue with a list of the selected blocks that are on a certain layer.
Thanks again.
-Kyle
Message 12 of 13
Kent1Cooper
@kyle_dean wrote:
.... Say I draw a selection area in autocad that grabs a lot of objects that i don't want and only want to continue with a list of the selected blocks that are on a certain layer. ....
Add the Layer entry to the (ssget) filter list.  That's the DXF-code 8 entry:
(setq ss (ssget '((0 . "INSERT") (8 . "YourLayerName"))))
Read more about (ssget) in the AutoLisp Reference >here<, and about the DXF code numbers for the various pieces of data about various entity types >here<.
Kent Cooper, AIA
Message 13 of 13
kyle_dean
@Kent1Cooper  Yall are amazing. Thanks for your reply. I hope to achieve guru level knowledge of Auto Lisp like you all one day!
