LISP - automatic coordinate dimensions for a free closed polyline
Message 1 of 32
Dear community,
I'm workin on Autocad Mechanical 2018 and I am looking for a LISP for automatic coordinate dimensioning for a free closed polyline. I found many LISPs and tested them all, unfortunately they either only work for orthogonal objects (base plate) or they only have linear dimensions.
The coordinate dimensions should look like this:
- UCS set to world
- with specific dimension style "AM_ISO_35mm"
- at each vertex of the polyline
- scale by scaling area (AMSCAREA) in which you are currently dimensioning
- zero points (starting points) - see example
- the polyline must remain a polyline, because it is important for further use
The double coordinate dimensions (e.g. right / left and top / bottom) will be removed later manually (via power-delete)
An example:
Many thanks in advance for your support
Replies (31)
Message 2 of 32
ВeekeeCZ
No dwg, no help.
Message 3 of 32
here one example
Message 4 of 32
ВeekeeCZ
Those arrows are made automatically too? (don't have AM)
Because I thought that those are made by dim style...
Message 5 of 32
yes, automatically according to my (privat) dim style in Mechanical
Message 6 of 32
ВeekeeCZ
Great. Then I'm lost at this point.
Consider posting this into the AM forums.
Message 7 of 32
hak_vz
Some three months ago I have created a script to automatically delete overlapping dimensions . Actually @ВeekeeCZ  has helped me at one point. I'll try to use some parts of that script to create dims the way you like. At the moment I'm half a way done,  so I won't post anything until I have something to show.
Miljenko Hatlak
Message 8 of 32
Hi @hak_vz ,
many thanks in advance.
Message 9 of 32
hak_vz
Here is first part of the code, just to show my idea. It creates bounding box around dimensioning object, and creates perpendicular lines from polyline vertexes to four segments. It removes all lines that intersect with object. I will tomorrow update code to create dimensions over those lines and to remove them from a drawing. Option is not to delete intersecting lines and then you can erase them with your code.
Miljenko Hatlak
Message 10 of 32
Sea-Haven
My idea pick
pline get co-ords straight forward.
make 2 list X & Y then sort
Get min point x and y this is bottom left
Draw Vertical lines x + foreach Y, length
Draw Horizontal lines Y + foreach x, length
Draw hor text
Draw ver text
Take mid point of X & Y do left right up down no need to clean up.
Time for a coffee !
; pline co-ords example
(defun getcoords (ent)
  (vlax-safearray->list
    (vlax-variant-value
      (vlax-get-property
    (vlax-ename->vla-object ent)
    "Coordinates"
(setq co-ords (getcoords (car (entsel "\nPlease pick pline"))))
(co-ords2xy)
(princ co-ords)
(setq plent (entsel "\nPick rectang"))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
Message 11 of 32
hak_vz
Try this. I have tried to do something else,  but then used method you use  in your sample.
At the end erase bounding box lines, match dim style properties rotate text and remove duplicates.
Miljenko Hatlak
Message 12 of 32
Hi @hak_vz ,
I just tested it, unfortunately the command is interrupted relatively shortly after the start, bevore the bounding box is completed. The box will not close automatically, the drop-down menu will be displayed only.
Message 13 of 32
hak_vz
Here is the latest version and I guess it will work ok.
In case of error please skim through code and check if all switches are ok wherever you see (command .....), since you're using German version.
Error you describe arises since switch "c" don't work in German version.
I can not replicate this error in English version.
Miljenko Hatlak
Message 14 of 32
hak_vz
Here is my finalized code.
(defun c:autodim ()
(defun pointlist2d (lst / ret)(while lst (setq ret (cons (list (car lst)(cadr lst)) ret) lst (cddr lst))) (reverse ret))
(defun LM:boundingbox ( obj / a b lst )
    (if
        (and
            (vlax-method-applicable-p obj 'getboundingbox)
            (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list obj 'a 'b))))
            (setq lst (mapcar 'vlax-safearray->list (list a b)))
        (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) ((eval b) lst)) a))
                (caar   cadar)
                (caadr  cadar)
                (caadr cadadr)
                (caar  cadadr)
(defun perperdicular_from_point_to_line (lin1 lin2 p / x1 y1 x2 y2 x3 y3 k m n ret)
;returns point on a line (line1 line2) as a perpendicular projection from point p
	(mapcar 'set '(x1 x2 x3) (mapcar 'car (list lin1 lin2 p)))
	(mapcar 'set '(y1 y2 y3) (mapcar 'cadr (list lin1 lin2 p)))
	(setq
		m (-(*(- y2 y1) (- x3 x1))(*(- x2 x1) (- y3 y1)))
		n (+(* (- y2 y1)(- y2 y1))(*(- x2 x1)(- x2 x1)))
	(cond
		((/= n 0.0)
			(setq
				k (/ m n)
				ret (list(- x3 (* k(- y2 y1)))(+ y3 (* k(- x2 x1))))
	ret
(defun getintersections	(obj1 obj2 / var)
     ; from RonJonP
     (setq var (vlax-variant-value (vla-intersectwith obj1 obj2 2)))
     (if (< 0 (vlax-safearray-get-u-bound var 1))
	  (vlax-safearray->list var)
     ) ;_ end of if
) ;_ end of defun
(defun init ( / e ent off plobj pts bbox p1 p2 p3 p4 k1 k2 k3 k4 uc_list po a b c i segs uc te to int)
    (setq e (car(entsel "\nSelect polyline to autodim >")))
    (if (not (setq off (getreal "\nDimensions offset from object <20>"))) (setq off 20))
    (cond
        ((and e)
            (setq plobj (vlax-ename->vla-object e))
            (setq pts (pointlist2d(vlax-get plobj 'Coordinates)))
            (setq bbox (LM:boundingbox plobj))
            (command "_.pline" "_non" (car bbox) "_non"  (cadr bbox) "_non"  (caddr bbox) "_non"  (cadddr bbox) "c")
            (setq p1 (car bbox) p2 (cadr bbox) p3(cadddr bbox) p4 p1)
            (setq k1 (cadr bbox) k2 (caddr bbox) k3 (caddr bbox) k4 (cadddr bbox))
            (setq uc_list (list (list p1 k1)(list p2 k2)(list p3 k3)(list p4 k4)))
            (setq po (entlast))
            (setq a (car bbox) b (mapcar '+ (car bbox) (list 0 (* -1 off))) c (distance a b))
            (command "_.offset" "_non" c (entlast) "_non" a "_non" b "")
            (setq e (entlast))
            (setq bo (vlax-ename->vla-object e))
            (setq bbox (LM:boundingbox  bo))
            (entdel po)
            (setq i 0 segs (list))
            (while (< i 3)
                (setq a (nth i bbox) b (nth (+ i 1) bbox))
                (if (> (car a) (car b)) (setq c a a b b c))
                (setq segs (append segs (list(list a b))))
                (setq i (+ i 1))
            (setq segs (append segs (list(list (car bbox)(last bbox)))))
            (entdel e)
            (setq i 0)
            (foreach seg segs
                (setq uc (nth i uc_list))
                (command "_.ucs" "w")
                (command "_.ucs" "_3p" (car uc)(cadr uc) "")
                (command "_.line" "_non" (trans (car seg) 0 1) "_non" (trans(cadr seg)0 1) "")
                (setq te (entlast))
                (foreach pt pts
                    (setq proj (perperdicular_from_point_to_line (trans(car seg)0 1) (trans(cadr seg)0 1) (trans pt 0 1)))
                    (command "_.line" "_non" (trans pt 0 1) "_non" proj "")
                    (setq to (vlax-ename->vla-object (entlast)))
                    (setq int (getintersections to plobj))
                    (entdel (entlast))
                    (command "_.dimordinate" "_non" (trans pt 0 1) "_non" proj)
                    (if (or (= i 1) (= i 3))
                        (progn
                            (setq ent (entget(entlast)))
                            (setq ent (subst (cons 53 4.71238898)(assoc 53 ent)  ent))
                            (entmod ent)
                (setq i (+ i 1))
                (entdel te)
(setvar 'cmdecho 0)
(vla-endundomark (vla-get-ActiveDocument (vlax-get-acad-object)))
(vla-startundomark (vla-get-ActiveDocument (vlax-get-acad-object)))
(init)
(command "ucs" "w")
(setvar 'cmdecho 1)
(princ)
(princ "\n Type Autodim to dimension an polyline ")
(princ)
If you find this usable, select this as final solution.
Miljenko Hatlak
Message 15 of 32
ВeekeeCZ
I knew this would be possible... nice, easy and quick! Just using built-in QDIM command.
See HERE
Message 16 of 32
Hi @hak_vz ,
These things have occurred during testig:
- UCS has turned 90 ° counterclockwise (X is vertical, Y is negativ horizontally), then the vertical dimensions "on the head"
- how can you set a specific user dimension style (e.g. "AM_ISO_Plate" or similar)
- i work in scalling areas (M1:15 for assembly, M1:5 for details), where the dim style takes over the scale from the scaling area. How can you set a temporare global dim factor M1:5 (for the details) in the scaling area? Now it use a global dim scale factor.
Many thanks for your help in advance, your LISP will save a lot of sleepless nights 😊
(and i can learn something new about it)
Message 17 of 32
@ВeekeeCZ ,
i know QDIM very good - was my tool until now, but this is not suitable for a work with 50+ details :-).
Thanks to the community, we can protect our eyes 😎
Message 18 of 32
hak_vz
My code works as follow:
1) It creates a bounding box around dim object
2) It moves in cc direction and creates ordinate dims
All the time it works in direction of bounding box side and takes her as a x direction
so for horizontal ordinate dim lines it rotates text for 270 deg
It should not change usc direction, and actually in each iteration **** first changes ucs to world
Before you use the code use command DIMSIZE to set scaling
In acad 2014 it all works ok
Miljenko Hatlak
Message 19 of 32
I tested it in AutoCAD Mechanical 2018, without good result (see DWG example in my previous post).
When I use QDIM for ordinate dimension and compare it with AUTODIM possibilities, the properties of both dimension methodes are difficult, especially for vertical dimension (by "_list" command):
Properties              QDIM          AUTODIM
associative             yes              no
type                         Y axis          X axis
All the vertical dimensions have wrong type (should be Y axis)
I try to understand why it is so and what can I do differently. But no idea.
Message 20 of 32
hak_vz
I'll have to change my algorithm.
Miljenko Hatlak
