Lisp auto wblock to separate drawings with number increments to the file name in autocad
thientuinfo
thientuinfo
 I found a lisp, but can only save 1 file with the name 001. Can someone help me how to save more files with increasing names from 000-999. Thanks everyone
(defun c:fwb ()
(setq pickset (ssget))
(setq file_name "D:\\file new\\001.dwg")
(command "_.WBLOCK" file_name "" (list 0.0 0.0 0.0) pickset "")
(command "_.OOPS")
paullimapa
*code updated*
try this:
; fwb wblocks files with increasing names from 000-999
; fwbres resets name sequence back to 1
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-auto-wblock-to-separate-drawings-with-number-increments-to/m-p/12427730#M458720
(defun c:fwb
 (/ file_name folder pickset) ; local variables
 (vl-load-com)
 (setq folder "D:\\file new") ; change folder name as needed
 (if (not **fwb_count**)(setq **fwb_count** 1)) ; initiate **fwb_count** as a global variable
 (if (not (vl-file-directory-p folder))
  (progn
   (princ (strcat"\nFolder Name [" folder "] Does Not Exist attempting to Create it..."))
   (vl-mkdir folder)
 (if (vl-file-directory-p folder)
  (progn
   (princ (strcat"\nFound Folder Name [" folder "]... Continuing with Wblock function."))
   (setq pickset T)
  (princ (strcat"\nFailed to Create Folder Name [" folder "]... Exiting Wblock function."))
 (while pickset
  (princ "\nSelect Objects to Wblock...")
  (if (setq pickset (ssget))
   (progn
    (cond
     ((< **fwb_count** 9)
      (setq file_name (strcat folder "\\00" (itoa **fwb_count**) ".dwg"))
     ((< **fwb_count** 100)
      (setq file_name (strcat folder "\\0" (itoa **fwb_count**) ".dwg"))
     (t
      (setq file_name (strcat folder "\\" (itoa **fwb_count**) ".dwg"))
    ) ; cond
    (if (findfile file_name)(vl-file-delete file_name)) ; delete any existing files matching name
    (command "_.OOPS")
    (setq **fwb_count** (1+ **fwb_count**)) ; increment #
    (princ (strcat "\nWblock successfully written to [" file_name "]."))
   ) ; progn
   (princ"\nNothing Selected.")
  ) ; if
 ) ; while loop
 (princ) ; clean exit
) ; defun
(defun c:fwbres ()(setq **fwb_count** nil)(princ)) ; defun
(princ"\nType [FWB] to execute Wblock sequence or [FWBRes] to Change Sequence back to 1.")(princ)
Paul Li
IT Specialist
@The Office
ВeekeeCZ
If you were a newbie, I'd say learn how cond works. That applies to red.
But seeing all the blue ones.. got a headache.
It could be so simple
(cond
  ((< n 10) ...)
  ((< n 100) ...)
@paullimapa wrote:
try this:
(cond
     ((= (< **fwb_count** 9))
     ((and (= (< **fwb_count** 100)(> **fwb_count** 9)))
     (t
    ) ; cond
thientuinfo
tks u so much !!!
paullimapa
You’re welcome. .cheers!!!
Paul Li
IT Specialist
@The Office
paullimapa
Yes, temp insanity on my part. Thanks for the reminder.
Paul Li
IT Specialist
@The Office
