Lisp and DCL Locks Up When Selecting Objects
I have a lisp and dcl that i am trying to create that will allow users to pick a button from the dcl and load the function associated with the button. The lisp will run is i run it without the dcl, but when i run it with the dcl the lisp locks up on selecting the objects. i need to to select the butoon and continue with the lisp function. Below is my sample code for the dcl and the lisp.
DCL...
CSASTATUS : dialog {
 label = "Udate CSA Ojects Per Status Colors";
   label = "CSA Status Updates";
    : button {
        key = "but1";
        label = "&Prelim";
        is_default = false;
        alignment = centered;
        fixed_width = false;
    : button {
        key = "but2";
        label = "&Engineering";
        is_default = false;
    : button {
        key = "but3";
        label = "&IFC";
        is_default = false;
    : button {
        key = "cancel";
        label = "&Close";
        is_default = true;
        is_cancel = true;
        fixed_width = true;
      } //end : dialog
Lisp...
(prompt "\nType CCC to run...")
(defun *error* (msg) (princ "error: ") (princ msg) (princ))
(defun c:ccc ();define the function
(setq dcl_id (load_dialog "CSASTATUS.dcl"));load the DCL file
 (if (not (new_dialog "CSASTATUS" dcl_id));load the dialogue box
 (exit );if not loaded exit
(action_tile "but1" "(doButton 1)");action_tile
(action_tile "cancel" "(done_dialog)")
(start_dialog)
(unload_dialog dcl_id)
(princ)
);defun
(princ)
(defun doButton(a)
   (cond
 ((= a 1) (Prelim))
 ((= a 2) (Eng))
(defun c:Prelim (/ PICKS SS1)
(vl-load-com)
 (setq PICKS (getvar "pickstyle"))
 (setvar "pickstyle" 0)
 (command "-layer" "s" "0" "f" "CL" "")
 (princ "\nSelect objects to change color: ")
 (setq SS1 (ssget))
 (command "_.CHANGE" SS1 "" "_properties" "_LAYER" "COL" "")
 (command "-layer" "s" "0" "t" "CL" "")
 (setvar "pickstyle" 1)
rkmcswain
Quick and dirty edits.... but it works for me....
(action_tile "but1" "(setq dobutton 1)(done_dialog)");action_tile
(start_dialog)
(if (eq dobutton 1)
  (prelim)
);defun
;;;(defun doButton(a)
;;;   (cond
;;; ((= a 1) (Prelim))
;;; ((= a 2) (Eng))
(defun prelim (/ PICKS SS1)
(vl-load-com)
 (setq SS1 (ssget))
 Your code was not crashing 2016 for me, but I was getting an unhandled exception. I called (done_dialog) before calling the (prelim) function, which includes the (command) function. I suspect this was a large part of the issue.
R.K. McSwain     | CADpanacea | on twitter
I just noticed that the cancel or close button still envokes that commands. Why?
rkmcswain
Because I was at lunch and didn't take the time to inspect everything 🙂
Probably because we didn't declare the variable "dobutton" local, so it's stays = 1 while you're in that drawing.
scot-65
Let's take a closer look at your code and properly structure it.
I see no errors in the DCL part. All looks good to me.
First, let's take advantage of the done_dialog return of an integer to start_dialog:
(action_tile "but1" "(done_dialog 1)")
(action_tile "but2" "(done_dialog 2)")
(action_tile "but3" "(done_dialog 3)")
etc.
(action_tile "cancel" "(done_dialog 0)")
Now, let's assign a variable to the start_dialog thingey:
(setq sd (start_dialog))
And finally, to enter into the *main* program:
(if (and sd (> sd 0))
 (cond
  ((= sd 1) ...)
  ((= sd 2) ...)
  etc.
 );cond
);if
The objective here is to first gather User input. Do not pass Go. Do not collect $200.
Once the user input is gathered, close the dialog and proceed to the main program.
[commands are not allowed when a dialog is open - which is how your program is currently structured]
As a helpful hint, avoid placing the call to done_dialog away from action_tile line.
This will help better read the code. For instance, I wish to take a "snapshot" of the
current state of each tile. I would do something like this:
(action_tile "accept" "(User_GET)(done_dialog 1)")
Where User_GET is a subroutine where I will gather [get_tile] all the tile values - as a LIST.
Another hint is to place subroutines or functions above the main program.
By doing so, and canceling out the first line "(defun c:CCC..." and the last line ");end CCC",
loading the program directly will not require a command to start the routine (the load
will start the routine).
I do have templates uploaded here on this site that may help.
Hope this helps.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
