Lisp - Align, Mirror
Lukasvop1
Message 1 of 13
Lukasvop1
Hi guys, I wonder for lisp that allow me Align object and after that automatically mirror like on picture.
order of the steps : 1.Align
                                  2.Scale - yes
                                  3.Mirror
                                  4.Delet source object - yes
Replies (12)
Message 2 of 13
ВeekeeCZ
Possibly like this...
(defun c:Almi ( / s p1 p2 p3 p4)
  (if (and (setq s (ssget "_:L"))
	   (setq p1 (getpoint "\nSpecify first source point: "))
	   (setq p2 (getpoint p1 "\nSpecify first destination point: "))
	   (setq p3 (getpoint "\nSpecify second source point: "))
	   (setq p4 (getpoint p3 "\nSpecify second destination point: "))
    (command "_.align" s "" "_non" p1 "_non" p2 "_non" p3 "_non" p4 "" "_yes"
	     "_.mirror" "_p" "" "_non" p2 "_non" p4 "_y"))
  (princ)
Message 3 of 13
Lukasvop1
Works perfect, thank you.
Message 4 of 13
komondormrex
hi there,
red question marked are lines, segments of lwplines?
Message 5 of 13
Lukasvop1
These are Lines, theoretically PLines.
Message 6 of 13
komondormrex
hi there,
check this one. need to select source entities, alignment source points 1, 2 and target entity.
;	komondormrex, nov 2023
(defun vector_multiplying (vector_1 vector_2 / x1 y1 z1 x2 y2 z2)
	(mapcar 'set '(x1 y1 z1) vector_1)
	(mapcar 'set '(x2 y2 z2) vector_2)
	(if (minusp (caddr (list (- (* y1 z2) (* z1 y2))
	      		  		 	 (- (* z1 x2) (* x1 z2))
	      		  		 	 (- (* x1 y2) (* y1 x2))
		) -1 +1
(defun pick_entity (_prompt group_0_list start_end_list get_segment closed_allowed / entsel_data target_entity)
	(while (and
				(if (vl-catch-all-error-p (setq entsel_data (vl-catch-all-apply 'entsel (list (strcat "\n" _prompt ": ")))))
						(setq target_entity nil)
						t
				(if entsel_data (setq target_entity (car entsel_data)) t)
				(if (member (cdr (assoc 0 (entget target_entity))) group_0_list)
					(if (= "LWPOLYLINE" (cdr (assoc 0 (entget target_entity))))
						(if closed_allowed
							nil
							(minusp (vlax-get (vlax-ename->vla-object target_entity) 'closed))
						nil
					t
	(if target_entity
		(cond
				(and
					 get_segment
					(setq picked_param (fix (vlax-curve-getparamatpoint
												target_entity
												(vlax-curve-getclosestpointto target_entity (cadr entsel_data))
					(set start_end_list (list (vlax-curve-getpointatparam target_entity picked_param)
											  (vlax-curve-getpointatparam target_entity (1+ picked_param))
					target_entity
				t
					(set start_end_list (list (vlax-curve-getstartpoint target_entity)
											  (vlax-curve-getendpoint target_entity)
					target_entity
(defun c:smart_align (/ source_entity_list source_points target_points alpha cos_alpha rotation_point sin_alpha
						target_entity vector_1 vector_2
	(prompt "\nSelect source arc or lwplines entities...")
	(setq source_entity_list (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "arc,lwpolyline"))))))
		  source_points (list (setq 1st_point (getpoint "\nPick source 1st alignment point: "))
							  (getpoint 1st_point "\nPick source 2nd alignment point: ")
		  target_entity (pick_entity "Pick target entity" '("LINE" "LWPOLYLINE") 'target_points t t)
	(setq rotation_point (inters (car target_points) (cadr target_points) (car source_points) (cadr source_points) nil))
	(if rotation_point
		(progn
			(setq vector_1 (mapcar '- (cadr source_points) (car source_points))
				  vector_2 (mapcar '- (cadr target_points) (car target_points))
				  cos_alpha (/ (apply '+ (mapcar '* vector_1 vector_2))
			  					 (* (sqrt (apply '+ (mapcar 'expt vector_1 '(2 2))))
			  						(sqrt (apply '+ (mapcar 'expt vector_2 '(2 2))))
			(cond
				((equal 0 cos_alpha 1e-8) (setq alpha (* 0.5 pi)))
				((equal 1.0 cos_alpha 1e-8) (setq alpha 0))
				(t (setq sin_alpha (sqrt (- 1 (expt cos_alpha 2)))
						 alpha (atan (/ sin_alpha cos_alpha))
	(foreach source_entity source_entity_list
		(if rotation_point
			(vla-rotate (vlax-ename->vla-object source_entity)
						(vlax-3d-point (mapcar '* '(0.5 0.5) (mapcar '+ (car source_points) (cadr source_points))))
						(* alpha (vector_multiplying vector_1 vector_2))
		(vla-scaleentity (vlax-ename->vla-object source_entity)
						 (/ (apply 'distance target_points) (apply 'distance source_points))
		(vla-move (vlax-ename->vla-object source_entity)
				  (vlax-3d-point (mapcar '* '(0.5 0.5) (mapcar '+ (car target_points) (cadr target_points))))
		(vla-mirror (vlax-ename->vla-object source_entity)
					(vlax-3d-point (car target_points))
					(vlax-3d-point (cadr target_points))
		(entdel source_entity)
	(princ)
updated_2
Message 7 of 13
Lukasvop1
Thank you, works nice but it have bit lack, I can't select more arc to be aligned at once. Can you please fix this?
Message 8 of 13
komondormrex
what do you mean more arcs?
Message 9 of 13
Lukasvop1
E.g. like on the picture above, that shape is created from multiple arcs. It's not typical example of vault but they're often created of many arcs.
I know it can be jointed to PLine and then your lisp works right.
Message 10 of 13
komondormrex
ha ha, never thought they are multiple arcs)
Message 11 of 13
Lukasvop1
Yes, they have. Typically in old churches, cathedrals, mansions, they're not symmetric seems like random..
Message 12 of 13
komondormrex
you get it. check update.
Message 13 of 13
Lukasvop1
Very nice, thank you.
