Link text to attribute
Hello All,
Is there a way you can build a block (dynamic or not) and have a piece of text (inside the block) linked to an attribute inside the block?
Inside the attached drawing, I show an attribute highlighted RED, which I want to change to "FA". I want the text below in MAGENTA to say "FA" too. I don't want to create 3 separate attributes to say the same thing. Is there a way to get that text to match what the attribute says?
Please see drawing attached
paullimapa
Thanks for responding. I loaded the lisp and it just shows a number. In my case, it said 209.  Not sure if I did it correctly.
