Line
Line
Line
I have a cust. line routine that takes 2pts. instead i am trying to have a line  such that when i pick the first pt i can see the line being placed and i can choose to use the ortho and all the other tool that comes with the normal line.
Kent1Cooper
I will assume that it uses (getpoint) to ask for the 2 points.  If so, and if the first one is something like:
(setq pt1 (getpoint "\nFirst point: "))
then if you add pt1 as an argument  to the (getpoint) function for the second point, you will see the line being placed [the "rubber-band" line from pt1 to the cursor location], and can use Ortho, etc.:
(setq pt2 (getpoint pt1 "\nSecond point: "))
Kent Cooper, AIA
