line type with soild arrow
muhamed_ragab92
Message 1 of 15
muhamed_ragab92
i want to make line type contain with soild arrow as attached photo
can i control on the length of soild arrow or direction of it?
Replies (14)
Message 3 of 15
DRW_CAD
You can also make a linetype using text & Wingding is a standard windows font & is all symbols and has arrow heads.
These are some erosion & sediment control linetypes I created. You can tweak the contents to get different arrow heads. Copy & paste into notepad & name with a .lin extensions and create the WINGDING & WINGDING3 text styles they reference in your drawing and map them to the TT fonts of the same name.
*R-SUB-SURF-DRAIN,Right Sub-Surface drain arrow
A,.5,-.2,["à",WINGDING,S=.15,R=0.0,X=-0.1,Y=-.07],-.2
*L-SUB-SURF-DRAIN,Left Sub-Surface drain arrow
A,.5,-.2,["ß",WINGDING,S=.15,R=0.0,X=-0.1,Y=-.07],-.2
*R-SUB-SURF-DRAIN2,Right Sub-Surface drain arrow
A,.25,-.01,["à",WINGDING,S=.15,R=0.0,X=0,Y=-.066],-.2
*L-SUB-SURF-DRAIN2,Left Sub-Surface drain arrow
A,.25,-.01,["ß",WINGDING,S=.15,R=0.0,X=0.01,Y=-.066],-.2
*R-DIVERSION,Right Diversion Flow
A,1,.001,["†",WINGDING3,S=.2,R=0.0,X=-0.1,Y=-.1],0
*L-DIVERSION,Left Diversion Flow
A,1,.001,["…",WINGDING3,S=.2,R=0.0,X=-0.1,Y=-.1],0
Message 4 of 15
DRW_CAD
Here is what they look like in dwg:
Message 5 of 15
muhamed_ragab92
I don't get what you mean about the winding & winding3 text style
Can you explain it for me or show me tutorial for it
Message 6 of 15
Sea-Haven
The windows built in fonts include Winding which is like lots of little symbols. Type A and get A
ASDFGHIJKLZXCVBNM
You need to understand how to get at extended fonts some times. In windows fonts can look at the characters so for say Arial
Message 7 of 15
muhamed_ragab92
that's the result from notepad @DRW_CAD @Sea-Haven
Message 8 of 15
DRW_CAD
to avoid that error, you need the text styles. AutoCAD doesn't reference fonts dir. type ST create a style named exactly as they are in the lineype definition and map them to the associated TT font. My example is confusing because I used the same name for the AutoCAD style as the font itself. But where my line type has winding in it, it's looking for an AutoCAD text style of that name.
Message 9 of 15
muhamed_ragab92
Can you send me a autocad plan for that line type ?
Message 10 of 15
Sea-Haven
Make a textstyle Windings
Message 11 of 15
Kent1Cooper
@Sea-Haven wrote:
The windows built in fonts include Winding which is like lots of little symbols. ....
Careful of the spelling -- the name of the font is WINGDINGS [and there are some others with number suffixes added], but in various Messages here it has been spelled in various incorrect ways.  But it doesn't really matter what you call the Style to which you assign a font [you can call it MickeyMouse if you want], as long as you use the same spelling of the Style name in the linetype definition, and as long as the Style called for in the linetype definition exists in the drawing.
Kent Cooper, AIA
Message 13 of 15
TomBeauford
I have a collection of linetype files including wingdings.lin saved in the Roamable Support Folder:
*LINE_dia,LINE_dia ---\_/---\_/---
A,3,-1,["t",WINGDINGS,S=1,Y=-0.45],-1.75
*Line_Arrow,Line Arrow ---  --->  ----  --->  --
A,3,-1,["\U+00E8",WINGDINGS,S=1,X=-0.3,Y=-0.45],-2
;A,3,-1,["è",WINGDINGS,S=1,X=-0.3,Y=-0.45],-2
*Big_Dot,Big Dots --- O --- O ---- O --- O --
A,3,-1,["l",WINGDINGS,S=1,Y=-0.45],-2
*Big_D-Dot,Big Dash Dot --- O --- O ---- O --- O --
S,.001,["_",Arial,S=2,X=0.09,Y=0.46],-2.2,["l",WINGDINGS,S=1,Y=-0.45],-3.2,["_",Arial,S=2,X=-1.55,Y=0.46]
*Four_Square,Four_Square --- <> ---  <>  ----
A,3,-1,["v",WINGDINGS,S=1,Y=-0.45],-2
*Hedge,Hedge
A,.01,-1,["|",WINGDINGS,S=1,Y=-0.45],-.2
*Square,Square --- [] ---  []  ----
A,3,-1,["n",WINGDINGS,S=1,Y=-0.45],-2
*Danger, --- DANGER ---  DANGER  ----
A,.3,["N",WINGDINGS,S=.05,Y=-.025],-.05,["DANGER",Swiss Light,S=.05,Y=-.025],-.29,["N",WINGDINGS,S=.05,Y=-.025],-.05,.1
By saving them in the same folder as my default Acad.lin file they're easily accessible from the load lintypes dialog box.
You have to make sure the WINGDINGS text style is defined in the drawing for them to work.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 14 of 15
Amriya_Exe
Shows bad definition.
Message 15 of 15
Kent1Cooper
That usually means there is no Text Style name in the drawing with the same name as the Style called for in the linetype definition.  See Message 11.
Kent Cooper, AIA
