line+midpoints = 'fast command'
mauro_ribeiroYJWMG
mauro_ribeiroYJWMG
Can I make some macro or keybord command  (like, if I wrote 'lk') to have a line than CAD ask me to selec to points and the line will be created ate midpoint? I know MTP or Shift thing but I want a short way.
Kent1Cooper
(defun C:LK () (command "_.line" "_m2p" pause pause))
Kent Cooper, AIA
mauro_ribeiroYJWMG
@Kent1Cooper I'm new at programming CAD. Where i have to put this code? Or I need to save like .lsp?
Ty man
Kent1Cooper
You can paste the code right into the Command line, then use the LK command name that it defines.  [Or, it's not necessary to define a command name -- you could just paste in the functional part:
which will just do it directly.]
But you don't want to have to do that every time, or paste in the definition in every drawing where you want to use it.  For wider application, paste it into a plain-text editor such as Notepad, and save it to a file with a .LSP filetype extension.  Use APPLOAD to navigate to it and Load it.  If you want it always available in every drawing, include the code in acaddoc.lsp instead of in a file of its own [my preferred choice of the options described >here< -- there are other approaches].  Or you can do both -- have it defined in a file of its own, and have that file loaded by a (load) function included in acaddoc.lsp.
Kent Cooper, AIA
Sea-Haven
Something like this maybe.
(defun c:mpp ( / obj end start)
(setq obj (vlax-ename->vla-object (car (entsel "\nPick object "))))
(setq start (vlax-curve-getstartPoint obj))
(setq end (vlax-curve-getEndPoint obj))
(setq mp (mapcar '* (mapcar '+ start end) '(0.5 0.5)))
(command-s "line" mp)
