Leader note changes to formula
1500961
Message 1 of 8
1500961
Hi everyone,
I am using autocad mechanical 2020.windows 10.
I have an issue. There is a Lisp i downloaded helps me to convert layouts to DWG.
The issue is whenever i use this tool it affects my leader note.
It make the text as a formula and it is hard to edit.
And to solve this issue i have to reset all autocad which makes me lose a lot of settings and styles i use.
You can find the issue in the attachments.
Please help me
Replies (7)
Message 2 of 8
1500961
Any help ?
Message 3 of 8
pbejse
@1500961 wrote:
Any help ?
Maybe it is unique to Mechanical 2020, I myself has never used or seen one, but I cant tell just by looking at the image you posted. perhaps a drawing file would clear things up for everyone.
Message 4 of 8
1500961
The issue isn't related to a definite drawing.
If i made a new drawing and i drew leader note the text will come with the same issue.
It is something relates to a setting and i dunno what is it
Message 5 of 8
pbejse
Thank you for that. I guess I have no hope of solving your issue, please accept my apologies, I obviously dont know what I’m talking about here.
Message 6 of 8
1500961
Thank you for contribution. At least you tried.
Thanks again
Message 7 of 8
pbejse
Thanks again
Message 8 of 8
Sea-Haven
In other packages like CIV3D, and probably Mechanical they can have proxy objects, which can be intelligent objects, looking at your image it looks like a field type of string. Pbe was hinting we need a dwg to look at what you have. If its possible to get the leader string it may be possible to remove all the hidden code, much like removing Mtext formatting.
