Leader and Mtext To Multileader
davidNNBWC
davidNNBWC
Hey I'm trying to write/find a Lisp code to convert a leader and Mtext to a multileader. i work in Civil 3d 2023 and have a ran into multiple files that i get from surveyors or architects where they have a regular leader and an Mtext right next to each other like they exploded them. Now i know i can go through the Multileader command and select Mtext however i feel like that takes too long and everyone i do i need to place the leader. does anyone have a solution?
I also tried to have a AI write some code the best i could have it come up with is the folowing but it always gives me errors.
(defun c:ConvertToMLeader (/ leader mtext leaderData textString textPos newMLeader leaderPoints mleaderObj acadDoc mtextObj)
  ;; Get AutoCAD Document Object
  (setq acadDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (princ "\nAutoCAD Document Object retrieved.")
  ;; Select a Leader
  (setq leader (car (entsel "\nSelect a Leader: ")))
  (if (not leader)
    (progn
      (princ "\nInvalid selection. Please select a Leader.")
      (exit)
  (princ "\nLeader selected.")
  ;; Select MText
  (setq mtext (car (entsel "\nSelect MText: ")))
  (if (or (not mtext) (not (eq (cdr (assoc 0 (entget mtext))) "MTEXT")))
    (progn
      (princ "\nInvalid selection. Please select a valid MText object.")
      (exit)
  (princ "\nMText selected.")
  ;; Extract leader vertex points
  (setq leaderData (entget leader))
  (setq leaderPoints nil)
  (foreach d leaderData
    (if (= (car d) 10) ; Extract leader points
      (setq leaderPoints (append leaderPoints (list (cdr d))))
  (princ "\nLeader vertex points extracted.")
  ;; Extract MText position and text content
  (setq textPos (cdr (assoc 10 (entget mtext))))
  (setq textString (cdr (assoc 1 (entget mtext))))
  (princ (strcat "\nMText position: " (vl-princ-to-string textPos)))
  (princ (strcat "\nMText content: " textString))
  ;; Ensure data is valid
  (if (and leaderPoints textPos textString)
    (progn
      ;; Create new MLeader Object
      (setq mleaderObj (vla-AddMLeader acadDoc (vlax-3d-point (car leaderPoints)) acLineWithArrow))
      (princ "\nMLeader object created.")
      ;; Add leader points
      (foreach pt (cdr leaderPoints)
        (vla-AddLeaderLine mleaderObj (vlax-3d-point pt))
      (princ "\nLeader points added to MLeader.")
      ;; Set MText content
      (setq mtextObj (vla-AddMText acadDoc (vlax-3d-point textPos) textString))
      (if mtextObj
        (progn
          (vla-put-TextString mtextObj textString)
          (vla-put-TextHeight mtextObj 0.2) ; Adjust text height if necessary
          (vla-put-TextAttachmentType mleaderObj acAttachmentBottomOfTopLine)
          (vla-put-TextLocation mleaderObj (vlax-3d-point textPos))
          (princ "\nMText content set in MLeader.")
        (princ "\nError: Failed to add MText to MLeader.")
      ;; Delete old objects
      (entdel leader)
      (entdel mtext)
      (princ "\nOld objects deleted.")
      (princ "\nMLeader created successfully!")
    (princ "\nError: Could not retrieve necessary data.")
  (princ)
(princ "\nCommand 'ConvertToMLeader' loaded. Type ConvertToMLeader to use.")
(princ)
ВeekeeCZ
You need to post a sample file. C3D often do things differently.
Also can try this @ronjonp 's routine.
It's from '09, maybe it has developed some thru the yeas.
pendean
Community Legend
Community Legend
apjones
Have you tried the select Mtext option in the MLEADER command?
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
komondormrex
@davidNNBWC wrote:
... where they have a regular leader and an Mtext right next to each other like they exploded them.
you have at least to show visually what you have before and want  to have after.
