LAYOUT TO JPG
LAYOUT TO JPG
sudarsann
LAYOUT TO JPG
sudarsann
When I using JPGOUT command in  layout (AutoCAD), Layout entities only converted into jpg format. Model entities are not converting. Is any system variable or LISP to convert both model and layout entities to be convert into jpg.
Regards
Sudarsan
ВeekeeCZ
You have to miss something.
Command: JPGOUT
Select objects or <all objects and viewports>:
This print all of it incuding viewported model objects.
Regular _plot works same?
paullimapa
BeekeeCZ is correct.  I would go with the Plot option and choose AutoCAD's built-in JPG-Web.pc3 to create a jpeg file.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
