layout reactor
layout reactor
Message 1 of 15
layout reactor
I have this layout reactor (see below) which I want invoked each time I
click a different layout tab (A2k obviously) but it fires multiple times
when switching layouts sometimes twice, sometimes 6 or 7 times. Anyone have
any ideas why???
;;Load a reactor to inform us of layout changes so we can update the title
block
;;functions to point at the current title block
(if (not *layoutReactor*)
(setq *layoutReactor*
(vlr-miscellaneous-reactor
nil
'((:vlr-layoutswitched . find_different_title_block))
) ;_ end of vlr-miscellaneous-reactor
Thanks in advance
Perry
Replies (14)
Message 2 of 15
This is the case with many reactor notifications.
My advice would be to use the CommandEnded reactor,
and act when the name of the command is "-LAYOUT".
> any ideas why???
> block
> nil
> Thanks in advance
> Perry
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* [email protected] */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 3 of 15
The only time I have had reactors fire multiple times was when the reactor
was created multiple times (when I kept loading the file while debugging).
From the code you posted, I'm not sure why you would be experiencing this,
unless it somehow ends up in a different namespace each time so your global
*layoutReactor* is not seen by subsequent loads.
Is this set up to run in a separate namespace? If so, then I think you will
have to export your *layoutReactor*.
Mike Weaver
"perry" wrote in message
news:[email protected]...
have
> any ideas why???
> block
> nil
> Thanks in advance
> Perry
Message 4 of 15
There are several reactors that behave the way Perry describes. Try setting
up a documentBecameCurrent reactor sometime. This behavior even spills over
into the ActiveX side of things. Place a msgbox in the Activate event of
ThisDrawing. You'll get prompted several times whenever you siwtch
documents.
Get free software and more at
http://msnhomepages.talkcity.com/protectionfault/foquendo
"Michael Weaver" wrote in message
global
will
> Mike Weaver
> have
> > any ideas why???
title
> > block
> > nil
> > Thanks in advance
> > Perry
Message 5 of 15
Good to know, Frank. I haven't run into this before.
Thanks for the heads up.
Mike Weaver
"Frank Oquendo" wrote in message
setting
over
> documents.
Message 6 of 15
Thanks everyone!
I think I will try Tony's approach first, I have used the "commandended"
reactor before to cure other strange behavior but didnt realize I could use
it for the layout command as well.
Message 7 of 15
Sound pretty reasonable to me Tony I'll give it a shot.
Thanks!
"Tony Tanzillo" wrote in message
Message 8 of 15
You will get "n" notifications, if you load the same functions for "n"
times.
-Pakutharivu
CADD Centre - Corporate Office
#5, Sir PS Sivasami Salai, Mylapore
CHENNAI - 600004, India
Ph: +91 44 4994678
FAX: +91 44 4971098
e-mail: [email protected]
http://www.caddcentreindia.com
Tony Tanzillo wrote in message
have
> > any ideas why???
title
> > block
> > nil
> > Thanks in advance
> > Perry
Message 9 of 15
Is there a way to have a lisp routine run before autocad switches to a new
layout when the tab is selected with the mouse? I've fiddled with the
vlr-miscellaneous-reactor a little and it seems to run the lisp after it has
switched layouts.
Brian
Message 10 of 15
Brian Hailey,
No, there is not such event available, may ask what are you trying to do,
why has to be before switching?
Luis
Message 11 of 15
You could use the SYSVARWILLCHANGE reactor and watch for CTAB and CVPORT to
change.
Eric S.
Message 12 of 15
I'm working on a lisp that will change the ltscale when the layout is
changed. If I change the ltscale after the switch to the new layout, the
linework does not look correct and requires a regen. If I can change the
ltscale before the switch, the linework looks correct after the layout is
regenerated.
Brian
"Luis Esquivel" wrote in message
> Brian Hailey,
new
> Luis
Message 13 of 15
Brian,
I guess I had a similar need which I solved by redefining the Layout
command, introducing a line of code that sets Ltscale to 1 and then issues
the original "._layout" command. It's not a reactor, but it solves the
problem. What I wanted to prevent was incorrect printing of non continuous
lines, which do not print as expected from a layout when Lltscale is not 1.
Alfredo Medina
[email protected]
> regenerated.
> Brian
Message 14 of 15
That's exactly my goal as well. (along with learning lisp)
Brian
"Alfredo Medina" wrote in message
> Brian,
1.
> Alfredo Medina
> [email protected]
the
the
is
> > regenerated.
> > Brian
Message 15 of 15
You could use the SYSVARWILLCHANGE reactor and watch for CTAB CVPORT and/or
TILEMODE to
change. This will fire bebore the layout switches.
Eric S.
