LAYLCK
LAYLCK
LAYLCK
I am writing an autolisp to lock certain layers (these layers do not have anything drawn on them in the project due to client request). I want to be able to type in the layer names instead of selecting an object, does anyone know how to do this?
Kent1Cooper
One approach:  You can lock any number of Layers in a Layer command, all at once, by typing in their names in one comma-delimited string.  [The same goes for assigning colors, linetypes, etc.]  So, in case some Users may not be aware of that, try something like:
(command "_.layer" "_lock" (getstring "n\Type all Layer names to lock, separated by commas: ") "")
Kent Cooper, AIA
pbejse
@Kent1Cooper wrote:
One approach:  You can lock any number of Layers in a Layer command, all at once, by typing in their names in one comma-delimited string.  [The same goes for assigning colors, linetypes, etc.]  So, in case some Users may not be aware of that..
To add to that , users can use wildcards
C-ANNO*,C-PROP*,*BANANA*,C-DIMENSION
stevor
To add to that, you can get the quantity of entities on each layer:
 (Defun Dxf_ (n L) (cdr (assoc n L)) )
 ; tabLe name List
 (Defun TbL_nL (tn / td L) (setq @Anonymous "tbL_nL") (whiLe (setq td
  (tbLnext tn (not td))) (setq L (cons (Dxf_ 2 td) L))) L )
  (setq NCDL nil  CDL nil)
  (foreach LNS (tbl_NL "LAYER")
   (setq ss (ssget "x"(list (cons 8 LNS ) )))
   (SETQ QSS (if SS (sslength SS) 0))
   (if ss (setq CDL (if CDL (strcat CDL "," LNS) LNS))
     (setq NCDL (if NCDL (strcat NCDL "," LNS) LNS)))
Where NCDL, None Comma Delimited List,
is as string of the layers without entities.
S
