Layer Change ( only Text )
k005
Advisor Advisor
Message 1 of 21
k005
Hello guys;
I want to change the layer named DOOR-WINDOW. But only text objects should be processed.
sample:
KAPI-PENCERE -----> Kapi-Ebat....bylayer...bylayer...bylayer
Color: 7
When I select the text object with the window, it performs the operation. Thanks in advance to the helper.
Accepted solutions (3)
Replies (20)
Message 2 of 21
ВeekeeCZ
You start...
Message 3 of 21
pendean
Community Legend
Community Legend
Message 4 of 21
Kent1Cooper
sample:
Color: 7
Do you want to change the Layer itself [your first phrase] or Text object(s)?  Do you want to move Text objects on that Layer into a different Layer ["change the layer" meaning change the layer of the Text, not the layer itself]?  Or do you only want to change their color?
KAPI-PENCERE means DOOR-WINDOW in English, so I assume that's the Layer name.  What is Kapi-Ebat [which means Door-Size] for?  Is that the text content of a Text object?  Do you want only Text with that content changed, or all Text on that Layer?
Etc.
Kent Cooper, AIA
Message 5 of 21
k005
I already started... 🙂
Message 6 of 21
k005
Message 7 of 21
k005
I'm adding a sample dwg right away... wait a minute..
-- added
Message 8 of 21
hak_vz
(defun c:foo (/ ss)
	(setq ss (ssget '((0 . "TEXT")(8 . "KAPI-PENCERE"))))
	(cond
		((and ss)
			(command "_.chprop" ss "" "LA" "Kapi-Ebat" "")
	(princ)
Sorry @k005  but you should be able to write this simple scripts by yourself. Creating selection set with filtering and applying  command function upon selected entities are the basics that any CAD user should know.
Miljenko Hatlak
Message 9 of 21
k005
@hak_vz
This code was partially... But not complete..
The reason : Lisp code crashes if there is no Kapi-Ebat layer... Otherwise it should create it.
Thank you.
Message 10 of 21
hak_vz
@k005 wrote:
@hak_vz
True. But you should be able to add a line of code that would test if layer exist, and create if it not. Add command line for "-layer" command with option make. Check other consequences of running this command. Attach your code.
Miljenko Hatlak
Message 11 of 21
ronjonp
Give this a try:
(defun c:foo (/ s)
  (if (setq s (ssget ":L" '((0 . "TEXT") (8 . "KAPI-PENCERE"))))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (entmod (append (entget e) '((8 . "Kapi-Ebat"))))
  (princ)
Message 12 of 21
Kent1Cooper
Advantage of appending the Layer name to the object's entity data:  It doesn't matter whether the Layer exists -- it will make it if it doesn't [with default color 7 and continuous linetype].
Advantage of CHPROP-command approach:  It can change the Layer of all of the selection at once -- no need to step through the selection set one object at a time.  But the Layer needs to exist.
Kent Cooper, AIA
Message 13 of 21
k005
Like okay. Since we are working in different dwgs, I will either enter the name of the layer to be searched from the keyboard or select the relevant (in the layer to be searched) text.
Message 14 of 21
k005
(defun c:fo1 (/ s lan)
(setq lan (cdr (assoc 8 (entget(car(entsel))))))
 (princ "\nKatman : ")
  (princ lan)
  (if (setq s (ssget "L:" '((0 . "TEXT") (8 . lan))))
      (entmod (append (entget e) '((8 . "Kapi-Ebat")(62 . 7))))
  (princ)
I get this error
error: bad SSGET list value
Message 15 of 21
Kent1Cooper
I get this error
You have the colon after the L.  Put it before.
Kent Cooper, AIA
Message 16 of 21
ronjonp
  (princ lan)
  (princ)
I get this error
Comments in the code below:
  ;; RJP selection check .. entget throws an error on a nil value
  (if (and (setq lan (car (entsel)))
	   (setq lan (cdr (assoc 8 (entget lan))))
    (progn (princ "\nKatman : ")
	   (princ lan)
      ;; RJP reformatted ssget call .. please study the differences
	   (if (setq s (ssget ":L" (list '(0 . "TEXT") (cons 8 lan))))
	     ;;(setq s (ssget "L:" '((0 . "TEXT") (8 . lan))))
	       (entmod (append (entget e) '((8 . "Kapi-Ebat") (62 . 7))))
  (princ)
Message 17 of 21
k005
It was very nice. Thank you. 🤗
Message 18 of 21
ronjonp
You're welcome.
Message 19 of 21
k005
Is it possible to add a name to it?
(setq istenen (getstring t "\nLayer adı giriniz : "))
(entmod (append (entget e) '((8 . istenen) (62 . 7))))
Message 20 of 21
ronjonp
;; Change this
;; To this
(entmod (append (entget e) (list (cons 8 istenen) '(62 . 7))))
