Latest PurgeIDs for acad 2017-2022 and Bcad 19-21
Use this link to get latest free tools I provide regularly:
This has the PurgeIDs (PID) command that is used to diagnose what files have excess AppIDs, and then clean them as needed. It does things "dbx" style, meaning no opening in the acad window, all in memory, like he Autodesk AppID cleaner does. Its the same code doing the cleaning, from Kean Walmsley at Autodesk.
The PID tool actually does several things, such as layer renaming, xref path revising and more.
Look at the help docs included.
It also has the "CC" command used to modify xref layer props with single click, and walk up and down the nesting ladder to see and possibly modify the layer at each level. Some other commands too...
Be sure to unblock the .net dll's as mentioned in the included instructions, you MUST do that for things to work, its easy. Thanks
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
