Label on contour line
HR2323
Message 1 of 22
HR2323
Required lisp to Put labels on polyline edges, as shown in the sample drawing
Replies (21)
Message 2 of 22
It seems that all you require is to label the Z coordinate value.
There's several out there if you Google it
Message 3 of 22
marlance
Hello
Check out this link below
label contour lisp
Polylines must have an elevation value.
Message 4 of 22
HR2323
It does not work well in this lisp code. The label displayed twice in close polyline. I should label one in close polyline.
(defun c:CLB (/ ss i ed p)
(vl-load-com)
  (prompt "\nSelect Contour.. ")
  (if (setq ss (ssget ":L" '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength ss))
      (setq ed (entget (ssname ss (setq i (1- i)))))
      (foreach x (list (car (setq p (vl-remove-if ''((x) (/= (car x) 10)) ed))) (last p))
    (entmakex (list    '(0 . "TEXT")'(8 . "CONTOUR LABEL")
            (cons 1 (rtos (cdr (assoc 38 ed)) 2 3))
            (cons 40 (getvar "textsize"))
            x
            ) ;_ end of list
          ) ;_ end of entmakex
    ) ;_ end of foreach
      ) ;_ end of repeat
    ) ;_ end of if
  (princ)
  ) ;_ end of defun
Message 5 of 22
ВeekeeCZ
Hi Sanju, try this code
(vl-load-com)
(defun c:ContoursLabel (/ ss i en p0 p1)
  (if (and (princ "\nSelect Contours, ")
	   (setq ss (ssget ":L" '((0 . "*POLYLINE"))))
	   (not (command "_.-LAYER" "_N" "Contour_RL" "_C" 6 "" ""))
      (setq en (ssname ss (setq i (1- i)))
	    p0 (vlax-curve-getStartPoint en)
	    p1 (vlax-curve-getEndPoint en))
      (foreach x (if (equal p0 p1 )
		   (list p0)
		   (list p0 p1))
			'(8 . "Contour_RL")
			(cons 1 (rtos (nth 2 x) 2 3))
			(cons 40 2)
			(cons 10 x))))))
  (princ)
Message 6 of 22
HR2323
BeekeeCZ,
                 Thank you very much for the code, last one more changes Text Rotation 45 degree.
Message 7 of 22
ВeekeeCZ
You're welcome. Here it is.
Spoiler
(vl-load-com)
	   (not (if (tblobjname "LAYER" "Contour_RL")
		  nil
		  (command "_.-LAYER" "_N" "Contour_RL" "_C" 6 "" "")))
		   (list p0)
		   (list p0 p1))
			'(8 . "Contour_RL")
			'(40 . 2)
			(cons 50 (/ pi 4))
			(cons 10 x))))))
  (princ)
Message 8 of 22
_Tharwat
My version:
(defun c:Test (/ _t ss i sn st nd)
  ;; Tharwat 19.08.2015	;;
  (defun _t (p s)
    (entmake (append '((0 . "TEXT")
                       (8 . "Contour_RL")
                       (40 . 2.0)
                       (50 . 0.785398)
                       (7 . "Standard")
                       (71 . 0)
                       (72 . 0)
                       (73 . 0)
                     (list (cons 1 (rtos s 2 3))
                           (cons 10 p)
                           (cons 11 p)
  (princ "\nSelect Polylines :")
  (if (setq ss (ssget '((0 . "POLYLINE"))))
      (setq sn (ssname ss (setq i (1- i)))
            st (vlax-curve-getstartpoint sn)
            nd (vlax-curve-getendpoint sn)
      (if (vlax-curve-isclosed sn)
        (_t nd (caddr nd))
        (mapcar '_t
                (list st nd)
                (mapcar 'caddr (list st nd))
  (princ)
Message 9 of 22
ВeekeeCZ
Since I'm still not come to taste mapcar and lambda, so tell me what is your attitude better if not just different.
Message 10 of 22
HR2323
Thank you very much both of you for your cooperation. Specially thanks to BeekeeCZ .
Message 11 of 22
_Tharwat
I am sorry BeekeeCZ , I did not mean any offense when I shared / posted my attempt in this thread .
I did not see you last codes because we posted almost at the same time and I saw a new reply from the OP asking about the rotation , I decided to post my that I wrote a few hours ago and I was outside the office and when I came back I posted the codes.
In regard to your question about the differences or about the use of mapcar & lambda , actually I just used mapcar when I THINK it is much more powerful than foreach function although there is no difference between the both of them in performance / outcome .
Message 12 of 22
ВeekeeCZ
Sorry for my English if that sounded offensive... I really tried to avoid that... no hard feelings. Thanks for your experience with mapcar.
Message 13 of 22
@ВeekeeCZ
@_Tharwat
Hi There!
First of all, I'm sorry my English is bad.
I really need help so much.
I saw your lisp here and I need help to change contour label interval  5, so the contour label will only show multiple by 5, it's like Elevation 110, 115, 120, 125.
Can you do a favor to help me?
or anybody else? Thank you so much.
(vl-load-com)
		   (list p0)
		   (list p0 p1))
			'(8 . "Contour_RL")
			(cons 40 2)
			(cons 10 x))))))
  (princ)
Message 14 of 22
Kent1Cooper
There are many rounding-off-to-the-nearest-multiple routines out there.  Here's one way to do it:
Change
to
  (cons 1 (itoa (* 5 (fix (/ (+ (nth 2 x) 2.5) 5.0)))))
Kent Cooper, AIA
Message 15 of 22
ВeekeeCZ
This should do the trick.
(vl-load-com)
(defun c:ContoursLabel (/ ss i en p0 p1 int)
	   (setq int (getint "\nSpecify interval: "))
      (if (equal (rem (last p0) int) 0 1e-6)
		     (list p0)
		     (list p0 p1))
			  '(8 . "Contour_RL")
			  (cons 40 2)
			  (cons 10 x)))))))
  (princ)
Message 16 of 22
@Kent1Cooper
@ВeekeeCZ
I really love how it works! but I forgot to say that I need "spacing" between label. Because that lisp too tight and close.
too tight & closetoo tight & close
I'm sorry, I do not understand lisp at all. but this "script" help my works.
Message 17 of 22
devitg
@Anonymous  Please upload you sample.dwg , so the LISP could be fix to your need.
Message 18 of 22
@devitg
@ВeekeeCZ
@Kent1Cooper
Okay, here sample.dwg that I want.
Interval 5
and the distance between labels not too close (Spacing)
Thank you all!
Message 19 of 22
Kent1Cooper
@Anonymous wrote:
…. I need "spacing" between label. Because that lisp too tight and close. ….
I think what you need is:
1.  A smaller text size;
2.  To clean up the contours, eliminating gaps or breaks.  The routine puts Text at the beginning and end of open-ended contours, or at the shared beginning/end of closed ones.  Your crowded contours of the same value must be from gaps in the contours, where it's labeling both sides of each gap.
If it is not to put the Text at the beginning and end, then it would need you to tell it where to put the Text for each contour.  That ruins the possibility of selecting multiple contours at once.
When the routine places a Text label, it doesn't know whether another contour in the selection will be "too close" to that later.  And if somehow it keeps track of the location of every label, to avoid later ones being too close, there will be times when a label cannot be placed where it is clear to which contour it applies.
Kent Cooper, AIA
Message 20 of 22
ВeekeeCZ
Best I can as of automation.
(vl-load-com)
(defun c:ContoursLabel (/ sel i ent int dst mxm pts)
	   (setq sel (ssget ":L" '((0 . "*POLYLINE"))))
	   (setq int (getint "\nSpecify contour interval: "))
	   (setq dst (getint "\nSpecify spacing distance: "))
    (repeat (setq i (sslength sel))
      (setq ent (ssname sel (setq i (1- i))))
      (if (equal (rem (last (vlax-curve-getStartPoint ent)) int) 0 1e-6)
	(progn
	  (setq mxm (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent))
		len (* 0.5 (rem mxm dst)))
	  (while (< len mxm)
	    (setq pts (cons (cons (angle '(0 0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getParamAtDist ent len)))
				  (vlax-curve-getPointAtDist ent len))
			    pts)
		  len (+ len dst)))))))
  (foreach pnt pts
		    (cons 1 (rtos (last pnt) 2 0))
		    (cons 40 2)
		    (cons 72 1)
		    (cons 73 2)
		    (cons 50 (car pnt))
		    (cons 10 (cdr pnt))
		    (cons 11 (cdr pnt)))))
  (princ)
