Keyboard shortcut for quickselect or filter option?
When doing elevation drawings, I often have to select all tile I've drawn from a drawing and rearrange it, copy to a new elevation, and so on.
I found the Quick Select and Filter commands and this does what I need. Now, can I make a keyboard shortcut so I don't have to go to first Filter and then choose which filter I need?
Thank you!!
Johanna_Esteban
Hi @Anonymous,
You can create keyboard shortcuts from CUI (see image), even create shortcut for Action Recorder when it is a series of repetitive commands.
But it would not make sense to create shortcut for a command as a filter to which you can create an alias, creating a new one in the pgp file, for example LL for LAYDEL, and not going through the keyboard side by side because of the location of the letters.
I will be attentive to your comments.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
natasha.l
Hello @Anonymous,
I will move this post to proper board for you.
It seems you are trying to create a customized command. You will have to formulate a string of commands or customized commands, such as an AutoLISP routine, ObjectARX command, a VBA macro, or a script.
Here is a list of AutoLISP programming language.
SeeMSixty7
You can use ALIASEDIT to add your alias to the acad.pgp file.
QSELECT is the command name for the Filter Dialog.
Good luck,
Sea-Haven
The filter command is one of those that you struggle to run as a command line etc or lisp, but you can make selection shortcuts using lisp defuns that can be called, Basically you use ssget and its filter capability, I just posted today another answer else where.
